SOURCE: Help my MPMAN!!!
If you couldn't find the firmware, here's a link - http://www.mpmaneurope.com/download.aspx?file_id=205 If the reset procedure suggested in the manual doesn't work, try taking out the battery for a day or two, that should also reset it. try switching the battery with another one. If it starts up when you connect it to the power cable then the battery or power supply system is at fault. If you still have a warranty, use it, if not, think how much a repair is worth for you and consult the shop you bought it with, or a similar shop that sells these products. Good luck
SOURCE: MPMan MP F35 T6
This player, oddly enough, only works with regular XP/SP1 - probably the only mp3 player in existence that is like that. I think the company's phrasing of the problem is quite humorous:
If you have WindowsXP SP2, we recommend that you go back to Windows XP SP1 before Microsoft solves the problem.
SOURCE: start switch hit & misses
you need to change the starter button the contacts inside are not working anymore
