Question about Samsung Computers & Internet
Hi. I have a Samsung Sansa MP3 clip-on player. I listen to audio books all the time. I order an audio book online. It comes to me in either a regular CD or an MP3 version (however they manufacture it). I have no problem downloading MP3 versions to my Sansa clip-on, but the player WILL NOT PLAY a regular CD audio book, although the software tells me that those files ARE on the player, because I did download them. WHY won't the regular CD audio books PLAY on my Sansa? Can anybody help me, please??? (I've tried everything, and I'm at my wits' end!)
Posted by pblevins78 on
Chris Hingee
  • Samsung Master
  • 32,281 Answers
Normally MP3 players can only play music/audio files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Posted on Apr 18, 2011
I cannot get my Sansa Clip MP3 Player to play recorded books. I downloaded the book chapter by chapter and I can see them when I use the computer to explore the player. I cannot get the player give me...
Audio books should be listed within the Music folder on your clip.. just scroll until you see it.
You may have to manually put the audio book into that folder via My computer beforehand.
WIndows media player does not recognize the audio book subfolder and will mix your audio books into the album mix.. but just ignore this
Jan 04, 2011 | SanDisk Sansa Clip MP3 Player
I have a message on my sansa clip that I want to get rid of so that I can continue to listen to my book. I can't listen till this is straightened out. It says synchronize to continue your music...
Audible books are protected, you can copy them into device, but you can't play them (...subscription...appearing ). You must use audible manager to sync audible books.
You should delete audible books that make pop up a message " synchronize to....", otherwise, your device always pops up the message when it meet the audible books.
Apr 06, 2010 | SanDisk Sansa Clip MP3 Player
Plays wma books, will not play mp3 books
convert the mp3 files to wma on a computer and then try
May 31, 2009 | SanDisk Sansa Clip MP3 Player
Audio book not going into audiobook section on sansa clip
There are two ways to delete files on your Sansa player.  You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device
For View, Fuze, Clip, e200v2, and c200v2 only
1. In playback mode, press the Submenu button.
2. Select Delete
METHOD 2 - Delete files using a PC
For all other Sansa players:
1. Connect your device to the PC.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your files are stored.
4. Click to select the files you want deleted and delete the files
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Sansa audio book scramble
The Sansa orders tracks alphabetically. It goes by the track name encoded internally, not by filename. You can use Media Player or some other program to rename the track, then transfer them to the Sansa.
Dec 31, 2008 | SanDisk Sansa e260 MP3 Player
Can't transfer Audible files to my Sansa Clip
The link to the operating manual (which includes the Audiobook instructions) is here:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
What I would do is drag and drop the Audible files from the folder that Audible creates to store your audiobooks to the Audible folder of the Sansa Clip, instead of using the Audible Manager.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
Sansa m250 doesn't continue playing from the same spot after power up
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files:
Audible
1) Adding audible books to your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-book.wmv
2) Adding books from an online library to your computer using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-books-from-online-library.wmv
3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-mobile-device.wmv
4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book.wmv
5) Deleting a book from your library using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book-library.wmv
6) Purchasing an audible book from Audible.com (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-purchase-book.wmv
May 13, 2008 | SanDisk Sansa m250 MP3 Player
MP players that play audio (talking) books
a sansa clip is excellent and has all the functions
You can even record fm radio as you listen to it
You can also use it like a dictaphone.
Dec 31, 2007 | Audio Players & Recorders
Sansa Clip Audiobook Question
Once I downloaded the newest firmware the audiobooks folder started showing up in the windows file explorer. So now I don't have to worry about using media player or anything else. I just plug in my sansa clip, open windows file explorer and drag the folders (1 for each disk) onto my player (into the audiobooks folder).
Here's the link for the download. If it doesn't come up you might want to reformat your sansa clip.
http://www.sansa.com/support/sansa_clip/faqs
Dec 30, 2007 | SanDisk Sansa Clip MP3 Player
Computers & Internet Logo
160 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
