SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
SOURCE: I have a Maytag MAV6300AWW,
The plastic pulley is worn out typically at the bottom- most common issue. It needs to be replaced. Thanks, please leave feedback or contact me again for more info if you need it.
SOURCE: Washer won't spin.
From Howtomendit: key point I missed was that you need to pull the motor apart after you have taken it out of the machine before you can get access to the screws holding the brushes in. (ie: unscrew the four bolts). Not as difficult or scary as it looked!
please read thro first.
first unplug it, pull it out so you have some work space, take off back
plate, remove belt undo (should be white rectangle plastic block with
wire attached), remove green+yellow wire undo bolts which hold motor to
drum, gently ease out motor (please be aware of sharp edges), run
screwdriver down 1 side of motor so you put it back together same way
you took it apart, unscrew 4 bolts that hold motor together take top
bit of dont loose spacer ring, place to 1 side, remove middle comutator
the end the brushes are touching will need a proper clean wd40 maybe
wipe clean with cloth so its not dull let dry, undo carbon brushes,
take plate off also clean then clean what they were attached to when
dry replace in reverse order gently (with new brushes) then replace
back on machine plug back in and test by running spin program found at
bottom of dail if i have my mod/num right let it get to full spin watch
motor if it sparks an looks like blackpool illuminations motors no good
will need new 1 sorry.
steven
SOURCE: Hotpoint WF220P has become very noisy during spin,
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Testimonial: "Thanks for the advice. It looks as if it's the bearings."
SOURCE: zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
