Question about Olympus VN-2100PC Digital Voice Recorder
I have just purchase the Voice-Trek VN-8100PC. I am trying to plug it into my MacBook so that I can move the soundfile to Garageband and Edit it. It doesn't seem to work. The Screen on the IC Recorder blinks "Please Wait" and the Mac doesn't recognize it. Is there a driver that I'm supposed to download?
Posted by learnwithpet on
George Mercado
    New Friend:
I wish people would pay attention he said MACBOOK not VISTA. I too have the same issue where I connect the cable and it says waiting but nothing happens.
Posted on Mar 12, 2014
5 Related Answers
Randy Morton
  • 479 Answers
SOURCE: Olympus vn-2100pc driver not installing
go through device manager and update driver
Posted on Aug 20, 2008
Anonymous
  • 919 Answers
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
If you checked their website and did not see the drivers for download then you will need to contact them to have them send the drivers to you. Their telephone number is 888-553-4448 option 5 and then option 2 for voice recorders.
Posted on Dec 22, 2008
Anonymous
  • 919 Answers
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Mar 23, 2009
Anonymous
  • 919 Answers
SOURCE: Need driver: Windows for Olympus digital voice recorder VN-120PC
igital Wave Player (2.0):
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Anonymous
  • 5 Answers
SOURCE: i can't transfer my files from recorder to pc
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Posted on Aug 25, 2009
How do I record dtxpress 3 on garageband?
Your best bet is to get a "midi to usb" cable. is use the M Audio Uno and have had no problems, then it will record as midi, so you can edit the hits later if needed.
Mar 30, 2012 | Yamaha Dtxpress III Electronic Drum Set...
I have an Alesis io2 audio-interface and a macbook pro. I'm using garageband software. I plug the interface into the macbook before I load garageband. (So standard protocol.) My problem is that when I...
sorry about your problem, i have the same issue. i think i solved i'm by using my midisport 2x2. Alesis fucked up on the midi with this unit. use an other midi sort, and that may fix the problem.
Jan 06, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
Software for my Olympus Digital Voice Recorder, Model: VN-3100PC
You can google your model software, but just plug it in to your computer, or use the cd that came with it. Just use windows explorer to get the files off, and audacity to edit.
Jul 03, 2009 | Olympus VN-3100PC Digital Voice Recorder
I need driver software for Olympus VN 4100PC voice recorder. Anybody can suggest the best site to download free?
You can down load every thing regarding Olympus VN- 2100PC from the following links.
Quickly find answers online to the most common questions specific to your product.
- VN-2100PC FAQ's
Instruction Manuals & Brochures
The complete set of documentation of your product. Most manuals are available for free download or you can purchase a paper hard-copy.
- VN-2100PC Instruction Manuals
- VN-2100PC Brochures
Software Downloads
Find program patches, software drivers, or firmware updates for your product.
- VN-2100PC Software Downloads
Accessories Guide
Discover a variety of compatible accessories for your product.
- VN-2100PC Accessories
I hope this will solve your issue.
Goodluck
If my solution proves useful please rate me.
Regards
Arjun
Mar 27, 2009 | Olympus VN-2100PC Digital Voice Recorder
Need driver for my macbook, i have a vn-240 recorder
The VN-240 is not designed to work on any MAC type of OS. Olympus does not have driver support for these devices with MAC.
Feb 28, 2009 | Olympus VN-240 Digital Voice Recorder
Recherche pilote pour vn-4100pc pour vista premium
Purchased an Olympus VN-4100PV digital voice recorder a couple of months ago at Radioshack. (no software came with it)
Recently purchased new PC with Vista 64-bit. Recorder will not work. Called Olympus today, 12-3-08 and was told no driver is going to be issued to remedy this situation, thus rendering my device useless.
Thanks for nothing Olympus product support.
Nov 18, 2008 | Olympus VN-4100PC Digital Voice Recorder
Olympus VN-2100PC Digital Voice Recorder Logo
410 people viewed this question
Top Olympus Audio Players & Recorders Experts
Lee Hodgson
Lee Hodgson
KBeaN1
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
