Question about Samsung CLX-3160 All-In-One Laser Printer
We cannot receive or send a fax. If I dial our fax number it rings as a normal phone and not the sound that a fax number makes. The machine is only a few months old.
Posted by manager425 on
Mark Schmit
  • Samsung Master
  • 1,915 Answers
Not sure how a fax machine is supposed to sound when it rings, before the fax answers it will sound exactly the same on the phone as dialing a regular phone number. If you are using distinct ring tone service where the fax line is supposed to double ring and it is not then it is possible that your phone provider has problems. Are you able to make a regular voice call on the phone line that the fax is supposed to use? If no, then it is definetly the line not the machine.
Posted on Apr 18, 2011
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Problem with my hp 640 fax
once you dial the number you fax will automatically start sending the the Fax signal which sounds like short beeps. This is done so the receivers phone (when answered) will recognized the beeps and switch to fax receive mode.  If you are getting the recording that you mentioned above, that means the number you dialed was not successful in making the connection.  Once you dial the number you should hear the phone ringing followed by some churping noises when the other end answers the call... then other churping and gargle like sounds initially as the fax proceeds.
sounds like your are having trouble with the number you are dialing.
Hope this helps..
~enov8
Feb 24, 2009 | HP 640 Inkjet Fax Machine
How do i enter the distinctive ring sound for the fax?
click on menu/setup button
then advanced fax setup-ok
answer ring pattern-ok
chose from single, double, double and triple, none-ok
Feb 06, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Canon Faxphone L80 - Alan Silva
To send a fax you do not need to enter anything into your fax. You have to make sure that you connect the telephone line to it's desgnated connector. You dial a number to send as if you are calling form a normal phone. If you ever get a ringing tone press start. You can enter any data trough the data registration after you make sure your fax is functioning properly.
Jun 24, 2008 | Canon FAXPHONE L80 Laser
Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Jan 08, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Samsung CLX-3160 All-In-One Laser Printer Logo
94 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
