Question about SmartDisk FireLite XPress USBFLXP60 60 GB USB 2.0 Hard Drive
SMARTDISK FIRELITE HARD DRIVE
I have an external hard drive, "smart disk FireLite.  Somehow it seems to be locked and it will not open when I plug it into the computer.  It will not even show that it is connected.  The light indicator on the device is on but that is as far as it goes.  In the past the Norton Virus program would identify it and scan each time it was plugged in.  But not now. How can I fix this problem?  Otherwise, I stand to loose hundreds of files and pictures. Thanks
Posted by CarlosBrenda on
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: smartdisk firelite won't be recognized on desktop-will on laptop
You have not said what system your computers are wroking under I would think your Sony is XP/2000 But the Dell is Win 98 - An I right? IF this is the case it means the drive has been formatted to NTFS which be read only on XO/2000 machines. The thing to do here is to load all your filed onto the Sony Then refomat to 32 bit - this makes a universal device but your Dell if I am right will not see the lappies stuff Come back with more detail
Posted on Jul 31, 2007
Anonymous
  • 55 Answers
SOURCE: Smartdisk Firelite 80GB-Stopped Working
this is a long shot , but i would look and see if you bent the small pins in the female plug on the drive.
good luck
Posted on Jan 15, 2008
Crankstart
Chris
  • 696 Answers
SOURCE: my smartdisk firelite does not appear anywhere on my computer
Sounds like you have a hardware failure either in the drive enclosure or the hard drive itself.
I suspect you may get lucky and find out it's just some of the circuitry in the smartdisk shell that is damaged.
Take the Smartdisk unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Posted on Aug 19, 2009
rolando ingking
  • 832 Answers
SOURCE: External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Posted on Oct 08, 2009
Arturo Balardo
  • 36 Answers
SOURCE: How do I open a smartdisk firelite model # USBFLB40
Go ti My computer icon, right click on it and click on explore. Should be show your new drive. If this is the case, right click the new HD in click on explore to see what is in there. My PC Doctor NJ
Posted on Mar 26, 2010
Why does windows media player not recognize my firelite smart disc as a device. my computer recognizes it
Try rebooting your computer with the Smart Disk plugged in. You can also try moving all the contents of the Smart disk to your computer and access from there.
Aug 14, 2015 | SmartDisk FireLite 40 GB Hard Drive
My firelite use to show up as firelite, now it showing up as the d drive and wont open. Its also asking me to format it in order to open, what should i do?
Junk it - the controller inside it has failed and the pc no longer recognizes it as a external disk and that is unfixable.
Aug 22, 2011 | SmartDisk FireLite 80 GB Hard Drive
How do I reformat my smartdisk firelite external hard drive for my new mac?
Go to the applications folder and then utilities open Disk Utility in the left box select you firelite and then clcik on the erase tab to your right. You can then select how you are going to format the hard drive standard for using with Mac only machines is Mac OS Extended (Journaled) or if you want to use with both PC and Macs is MS-DOS (FAT). Then name your drive and click on erase. Hope this helps.
Feb 01, 2011 | SmartDisk FireLite 80 GB Hard Drive
Computer repeatedly requests restart when smartdisk plugged in
try to scan your smart disk to another computer, your hard disk just hit by a trojan virus
Jun 28, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
Mar 26, 2010 | FireLite (USBFLB80) Hard Drive
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Smartdisk firelite
please use a recovery program for mac and then once all files are recovered then repartion hdd in disk utility then copy back all files to hard drive or change your external drive as you are the fourth person to have this problem with firelite hard drive for the mac sounds like a compatabilly issue with mac os systems
Jun 01, 2007 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite XPress USBFLXP60 60 GB USB 2.0 Hard Drive Logo
50 people viewed this question
Top SmartDisk Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
