Question about Canon imageRUNNER 5000 Copier
I just bought imagerunner c5870u and when it warms up, its making a noise, sort of like gear on gear noise. This worries me a lot because i know that its not suppose to make any noise. let me know thanks
nikhil chachapara
    New Friend:
  • 140 Answers
In this machine thera are fixing roller which are rotate and make some noise.
so dont worry there is no problem.
Posted on Apr 18, 2011
  • Anonymous Apr 18, 2011
    also the paper get jammed up almost every copy
Whine in 6th gear at 60mph which increase in pitch as speed rises
Yes I would be worried that a dealer would blame a gearbox ratio whine on the engine
What you could do is check the model forums to see if anyone else has the same problem also visit a couple of independent mechanics to ask them what they think
What sort of warranty do you have with that dealer as he may be trying to run the clock down on the terms covering the gearbox
Jan 16, 2016 | Cars & Trucks
N16 manual makes a whiring noise when slowing down from 60kph in 4th, stops when put into nuetral
sounds like a bearing is on the way out in the gearbox, nothing really to worry about yet, if it is still going into gear, and not making a grinding noise.
mine makes a whirring noise when accelerating through 1-3rd gears.
It's when there is grinding and growling in the gear box that you need to worry.
Nov 11, 2014 | Cars & Trucks
Anti lock brakes activate and make loud rubbing and clicking noise on normal stops on cold days (less than 40 degrees).
If the issue goes away when the car is hot, then it's likely not a sensor issue. Check the brake caliper for free moving and check the caliper's pistons to make sure they aren't seized.
Check the condition of the brake disk and pads.
Nov 03, 2012 | 2006 Nissan Quest
MIni Cooper makes a growling noise in low gear, especially when engine is cold
SORRY BUT UR FIRST GEAR COG IS WORN OUT, THE SYNCRO IS HAVING A TAD OF TROUBLE.. WHEN IT WARMS UP,IT ENLARGES AS STEEL DOES WHEN HEATED... HENCE NO PROBLEM WHEN UR CAR WARMS UP.. UR BEST AND CHEAPEST WAY OUT IS A CHANGE OVER BOX..GOOD LUCK
Aug 24, 2012 | MagnaFlow 2007 Mini Cooper - S,...
How to remove canon Image runner c5870u Hard Drive ? Where is it located? It is not the same as 5000
Hello Zak
The hard drive for the 5000 is located at the rear of the machine in the upper left controller box as you know. The 5870's hard drive is to the right, just below the "main board". Remove the back cover. To your upper right you will see the enclosure that houses the main board. Directly below it is a box with a cover on it. That's the controller box. Remove this cover and the hard drive will right at yours eyes. You have indicated that you are familliar with the 5000 series, which means you know how to proceed now that you have located the HDD. Have a great one !
Jan 20, 2011 | Canon imageRUNNER 5000 Copier
Where do I find the waste toner box. I have an IR C5870U
Rear right hand side, there is a rectangular panel with one screw at the top. Undo the screw and remove the waste toner box,
Feb 10, 2010 | Canon imageRUNNER C5800 Copier
I just bought a 2005 royal star venture. It's a great bike. The problem is a gear noise very loud when a ride in a constant speed. The noise become very loud and it very unpleasant after more than a hour....
Hi: It is "normal" for most royal star ventures to have a loud chirping sort of gear noise at certain rpms. Mine does it in every gear. It is especially noticable at between 100 and 110 kms/hr. If you increase or decrease the speed it gest better. This noise is because of the straight cut gears. Yamaha does this for strength and reliability but it is annoying. You can read more about it on the Venture owners sites such as The Venturers or VentureRider.org. It is nothing to worry about but I know it is annoying. Mine does it too. The RSV has a few quirks like this. nothing serious but somewhat annoying. THe other common thing is that the speedometer reads about 7% high. Mine does and many do. However, it is a very smooth, and very reliable bike. Hope that helps.
Jun 11, 2009 | 2005 Yamaha Royal Star Venture
I bought a printer cannon mp240 and when its going to start printing it makes a strange noise i want to know if thats normalll thanx
Depends what you mean by 'strange noise'. If this was the case ever since you bought the machine, then its normal, if you do not get any printer errors. Most printers make noises while they are initializing, lots of gears and stuff moving around inside...
If this is a fairly new occurrence, please explain in greater detail, so I can provide a solution (if there is one:)
Oct 26, 2008 | Office Equipment & Supplies
Samsung TX-P3271H Noise on cold start
greetings from belize that noise is normal it is just the boost up voltage that the set is hauling to operate.nothing to worry about.good luck.
Dec 21, 2006 | Samsung DynaFlat TX-P3071WH 30" TV
Canon imageRUNNER 5000 Copier Logo
114 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
