Question about Ovens
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Posted on Apr 19, 2011
Hi cjohnson539,
If the timer is flashing "0:00", you must reset the machine. You may have experienced a power outage. To reset it, just turn off the circuit breaker for a few minutes then turn it back on.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 18, 2011
the reply you gave me didn't help. I switched off the oven and the clock came back on and I couldn't move it. It has never flashed - it is constant.
You didn't read my complaint. I didn't say the timer was flashing. It just shows Auto 0:00 and won't move. I've used the circuit breaker and nothing has changed.
