The memory card in the camera has been locked. if you remove the memory card, you will see a small tab on the card and it is likely switched to the "lock" position. This can happen easily by accident if you are handling the card. Simply slide the switch on the memory card away from the lock position and you should be back in business.
Testimonial: " That was tfe problem thank you very much,larry"
