Question about Jabra BT250 Consumer Headset
1. Switch Bluetooth headset off.
2. Press and hold the answer/end button until a solid blue light comes on. Headset in pairing mode.
3. Go into phone's bluetooth options and "search/look" for devices. you should see the headset.
4.Pass code is "0000"
should connect and be good :)
hope this helps
Posted on Apr 17, 2011
sorry i grabbed the wrong book. this should help you. my apologies...
It is possible to reset and test the headset. Make sure that the
headset is powered off. Press and hold the answer/end button
and the on/off button at the same time for 10 seconds.
The headset will automatically turn off after approx. 10 seconds.
The next time you power on, the headset will go into pairing
mode as the first time you powered your new BT2070 on.
Jun 13, 2011 | Jabra Bluetooth Headset - BT2070
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Feb 22, 2011 | Jabra Bluetooth Headset - BT2070
Jan 24, 2011 | Jabra Bluetooth Headset - BT2070
Jan 15, 2011 | Jabra Bluetooth Headset - BT2070
Jan 03, 2011 | Jabra Bluetooth Headset - BT2070
Oct 08, 2010 | Jabra Bluetooth Headset - BT2070
Sep 24, 2010 | Jabra Bluetooth Headset - BT2070
Mar 22, 2010 | Jabra Bluetooth Headset - BT2070
Feb 11, 2008 | Jabra BT350 Bluetooth Headset Headset
124 people viewed this question
