How do I reset the bios cause when I enter the setup wont let me click on it
When you go into BIOS Setup Hector, you can no longer use your mouse
You have to use the Keyboard
When you go into BIOS Setup you are automatically in the Main menu
To go on..........
There are 3 main BIOS manufacturers. Some smaller ones too, but doubt they wrote a BIOS program for your laptop.
Phoenix, Award, and AMI.
Award merged with Phoenix now.
There are also different versions produced by EACH BIOS manufacturer.
Therefore I cannot just start guiding you, without knowing.
Some examples however......
This style has the menu's across the Top.
One example - Main / Advanced / Security / Power/ Boot / Exit
Use the Left Arrow key to highlight the menu you want, then press the Enter key.
The navigation guide is at the bottom, and to the Right.
DOES NOT state navigation guide.
Tells you how to navigate around in BIOS, and how to make changes, and Save Changes.
Same thing for a BIOS Setup example, that has the menu's listed i n an order.
Standard BIOS Features (Standard CMOS Features)
Advanced BIOS Features
Integrated Peripherals
Power Management Setup
PnP/PCI Configuration
Etc.
Use the Down Arrow to highlight the menu you want, then press the Enter key.
The navigation guide at the bottom, tells you the key to press, to make changes.
THEN Save Changes.
IF you do Not Save Changes, it will be like you have done nothing at all.
It's because you HAVE done nothing at all. Just looked around, unless you save changes.
[Usually the Page Up or Page Down key; or the Minus ( - )
or Plus ( + ) key; is to make changes.
Change Value ]
You may see F12 to save changes, or a Y/N, or Yes/No
The Y is just shown as an upper case Y for clarity. Press the lower case y.
Then press the Enter key.
If everything goes bad:
Look at the navigation guide at the bottom, in BIOS Setup.
You will see a key listed to press, that is Load Default Settings.
Usually an F6, but don't quote me on that.
You made a boo-boo in BIOS Setup?
Go back into BIOS Setup. Find the Load Default Settings key.
Press it, then the Enter key.
Now you are back to square 1.
Regards,
joecoolvette
