Question about Olympus mju 740 Digital Camera
My Olympus mju 740 keeps switching off
I bought this camera a year ago, together with its u/w housing. At first it worked well but after about a month it the screen started to go black but the red pilot lamp would stay on as though it was recording a picture. sometimes it comes back on automatically, while other times I have to switch it on again.
It can happen when I try to shoot a picture and sometimes on its own.
All this happens only when it is in the housing, irrelevant of the depth (10 mt to 40 mt).
I sent it to Olympus but they returned it saying there was nothing wrong, but the problem persists. Sometimes this can go on during the entire dive.
Has anybody had a similar problem?
Cheers
Ed
Posted by Ed Dirckze on
Tony Parsons
  • Olympus Master
  • 6,255 Answers
Just use it on dry land
Posted on Mar 28, 2017
5 Related Answers
Jeap
Jose Pais
  • 114 Answers
SOURCE: Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Posted on Feb 28, 2007
Anonymous
  • 6 Answers
SOURCE: C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Posted on Jan 14, 2008
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: Underwater photography problems with MJU 740
hmmm..well...let's see...poor resolution comes from one of two sources.
focal lengthe issues..
ocular clarity.
guess we'll try focal length...did you check to see that the housing and the lens are compatible, and perhaps you are experiencing refraction 101?
Posted on Apr 02, 2008
Anonymous
SOURCE: Olympus mju 410- Orange lamp flashing
I had this happen and fixed it by removing the battery and leaving it out overnight and making sure it was fully charged - the next day battery inserted and it was ok. Prior to inserting battery I opened shutter cover and help down shutter release to try to drain any residual power. - Worth a try.
Posted on Aug 21, 2008
pishta68
Steven Wander
  • 594 Answers
SOURCE: C8080 acting weired
The mode dial switch, zoom and power are all on the same ribbon cable. If you can spray some electrical contact cleaner into the crease of the mode dial, power button and zoom lever, it may be enough to get thing going again. I would try this with the camera inverted to reduce the spread of the cleaner. The upgrade process takes about 35 seconds. Make a file called firmware on your memory card, download the .bin file into the firmware folder and turn on the camera in play mode. The current version of the firmware will appear and an OK, press "OK" and the firmware will start to update. Do this after a factory reset as you stated that it was stable for 30 minutes. Good luck. Contact me pishta68 at hotmail dot com if you have any questions. I have 2 and a "half" of these cameras. I think the most current firmware is v757-78
Posted on Sep 10, 2008
I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
Oct 25, 2010 | Crosman Optics
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Dust stuck under glass on the lcd screen of my d60
If you purchased your D60 new, you could sent it in to Nikon for cleaning but personally, I'd wait a while if it's not affecting the camera's functions. If you need warranty work within the first year, you can send the camera in for that work, and they'll clean under the LCD while servicing the camera.
May 31, 2009 | Nikon D60 Digital Camera
Easyshare C713 LCD view is flushed out.
you push on the little 'i' button thats right under the delete button.
May 14, 2009 | Kodak EasyShare C713 Digital Camera
My screen went black after i took a picture
It's very possible that the problem is that the shutter is stuck, which is a known Canon issue on the powershot cameras, mainly on the S2 and S3 models, which it happens after some time (weeks or months) thata camera is not used.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires the skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S3".
Best regards,
Nov 27, 2008 | Canon PowerShot S5 IS Digital Camera
We have a new Samsung 10 megp. camera.
we are going back to the Argos Store where we bought the camera to see if they will exchange it for another one as we have the receipt when we bought it two months ago.
Oct 02, 2008 | Cameras
Problems taking pictures
Six months - Yes warranty.
Yes vendor still liable
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Olympus mju 740 Digital Camera Logo
51 people viewed this question
Top Olympus Cameras Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
