Question about Canon PowerShot SD1100 IS Digital Camera
Loaded software, but when I connect camera, the computer gives an error message "failed to initialize the program". Can't get any further. Thanks.
Posted by marysue_fish on
Ty Price
    Brigadier General:
  • 11,967 Answers
Usually, it's a good idea to restart your computer after installing a new program. Did you do that?
Posted on Apr 17, 2011
Cannot download pics from GE X5 camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 29, 2013 | GE X5 Digital Camera
Software is unable to find Olympus Digital camera connected to USB port
Dec 31, 2012 | Olympus TG-320 Tough 14MP Blue Digital...
I have an Olympus X-44, its new and worked fine, but since I had to install a new hard drive this and another digital camera shuts down my computer everytime its connected to my pc, I need the cameras for...
Obviously there is a camera firmware issue. You said you have printers can you see if one of the printers has a set of memory card readers for "Direct Printing these look like Odd looking USB ports but memory cards plug into them. You can use one of these ports to bypass your camera download system and camera software. The files can be loaded directly to your computer hard drive to a New folder you create in "My Documents" this system has now stepped around both your camera firmware and camera computer software. If you have a Photoshop program you can open and do what ever you want to these images. Failing having a printer with memory card reading capabilities the readers themselves are fairly inexpensive. Hope this was of some help
Mar 16, 2011 | Cameras
Suddenly when I try to download pictures from my camera, the camera utility window opens briefly displaying my pictures then an error window shows that says "failed to initialize program" and it...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 11, 2010 | Canon PowerShot SX110 IS Digital Camera
Recent;y bought a mew laptop with Windows 2007 as the operating system. I loaded the CD that originally came with my Canon EOS Digital Rebel XT (EOS Digital Solution Disk v 10.0), then downloaded the...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Nov 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Not Able to download pictures from Vivitar 5188 using Windows Me.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Nov 02, 2008 | Vivitar Vivicam 5105s Digital Camera
Data Becker Music CD Recorder 3.0 won't run on my new computer
If you are using Vista it won't run on it. I am having the same problem and looking for an update of it. I have used it on XP with no problem.
Mar 01, 2008 | Computers & Internet
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Paul Green
Are you a Canon Camera Expert? Answer questions, earn points and help others
