Question about Universal Health & Beauty
I have a mayfair freerider scooter and all of a sudden it wont charge up. charger says abnormal charge. Is there something wrong wiyh the batteries or charger?
Posted by riceyiphone on
lennieg2000
  • 692 Answers
Try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Posted on Apr 18, 2011
Hi, my wife's freerider Mayfair mobility scooter keeps going slow, have turned speed control down but still seems to loose power, doesn't stop just slows then reverts back to the speed set.
there are four possible reasons why a mobility scooter loose power including the user weight (vs. max weight of a mobility scooter), the weather condition, the riding routine and the battery age. You can check those factors to figure out the root cause. http://trustedmobilityscooters.com/reasons-mobility-scooters-loose-power
May 06, 2017 | Cars & Trucks
Want to see why my batteries wont charge. Product is new !
Is the charger getting power? Is the power reaching the battery pack to charge them? If you answer yes to both questions then something has to be wrong with the battery pack.
Jul 25, 2015 | Pride Mobility Victory 3 Wheel Electric...
How to change the batteries on a freerider mayfair?
The batteries are located under the seat. you will need to remove seat and then the plastic cowl that covers the batteries and drive compartment.
Mar 28, 2015 | Health & Beauty
How do I get to the batteries on my mayfair freerider
Lift the seat off. remove seat mount by removing pin or screws. Lift plastic cover off carefully but mind cables going to lights. These can be unplugged. And there should be your batteries.
Oct 19, 2014 | Health & Beauty
Freerider mobility scooter
hi, okay there two things the batteries and the charger, can you try another charger ?
1. Batteries need replacing ?? make sure battery terminal connections are tight.
2. How long are you charging the batteries for ? i hear you say that's a silly question however you be surprised how many people charge their batteries for a hour then remove the charger.
3. Is the charger faulty ?
4. there is a remote possibility of a controller fault however this is not common..
In relation to the charger if you're in the UK, I offer a free testing service , you only pay the return postage...
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Health & Beauty
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
Health & Beauty Logo
234 people viewed this question
Top Universal Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you an Universal Health and Beauty Expert? Answer questions, earn points and help others
