Question about Daewoo FRSU20IA Freezer
My daewoo frsu20IAI side by side is playing up. Its not freezing at the of freezer and is leaking from the bottom,its 2 year old and now the fridge has stopped cooling to the right temperature. I need a repair manual to check out the various parts .any ideas someone suggested changing the air sensors on the fridge and freezer, but need to know where these are .,Thanks in anticipation. Peter.
Posted by peter_roper1 on
Ken Wieczorek
    Sergeant:
  • Daewoo Expert
  • 451 Answers
Http://www.partmaster.co.uk/search.pl?query=FRS+2031IAL
Posted on Mar 02, 2017
1 Related Answer
mike cooper
  • 884 Answers
SOURCE: Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Posted on Apr 29, 2012
3 year old Frigidaire upright turning ice cream to soup. Meat OK for now. Can't find the manual (of course) or locate the thermostat. Where is the thermostat? other ideas?
the fridge section will not freeze ice cream as the lowest setting 1- is not cold enough
The thermostat is normally on the side panel inside the compartment and is measured 1-10 with 4 being around the best setting
if you are referring to a 2 door fridge where the top or bottom section is the freezer, that temp will be preset in the factory and has nothing to do with the thermostat but indicates - door not sealed properly
compressor failure and needs a technician to check out the reason why
Jul 01, 2018 | Frigidaire Freezers
Daewoo frsu20iai freezer builds ice at bottom and starts to defrost some items?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Aug 25, 2014 | Daewoo FRSU20IA Freezer
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Apr 28, 2012 | Daewoo Freezers
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
Aug 12, 2009 | Maytag Freezers
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 | Freezers
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Daewoo FRSU20IA Freezer Logo
718 people viewed this question
Top Daewoo Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
