Question about Sony Playstation 3 (PS3) Console
Error code 80710092 - Sony Playstation 3 (PS3) Console
Posted by krisstephens on
Anonymous
    New Friend:
  • 52 Answers
Try creating a new username and password. This seems to be a common issue currently and people are reporting that this has worked for them.
Posted on Apr 17, 2011
Anonymous
  • 105 Answers
This means you've been signed out of the playstation network. A problem with your broadband, not your PS3. Check the connection of the ethernet cable from your router to the ps3. Then switch off at the mains both your ps3 and your router. Leave for 30 seconds then turn both back on. Wait till the blue lights on your router are all steady blue not flashing red or orange. Then turn on your PS3, go to network settings, then internet connection test. This will check your internet connection, and whether or not you're signed in to PSN, and also your internet download/upload speed.
Hope this helps.
LJ
2answers
What means 80710092 error code?
hi there,
not sure if you have solved this problem already, but the error code is related to the playstation network and not been able to connect to it for whatever reason(there could be many). I've attached a link below to try and solve the problem for you(if you already have not done so. Thanks.
Tutorial on How to Fix PS3 Error 80710092 eHow
/ERROR 80710092
-ISSUE CONNECTING ONLINE
-Cannot connect to the interent or PlayStation Network. This may be caused by scheduled maintenance or issues with your internet connection
-TO FIX
1. Turn off your PS3, your router, your modem, etc.
2. Let everything stand turned for at least one minute.
3. Turn on you router/modem and wait for full power up (i.e. All lights lit)
4. Turn on your PS3 and try to access PSN
4helpful
2answers
Why is this error 80710092 keep coming up
On the PlayStation 3, the error 80710092 can mean that the PlayStation Network is currently down. Try again later.
2answers
I CAN'T SIGN IN TO PLAY STAITION NETWORK ERROR CODE (80710092)
ERROR CODE (80710092) can mean incorrect password, incorrect user name or bad internet connection check your user name and password and if that doesn't work then disconnect your ps3 from the internet and then reconnect
3helpful
3answers
What do i do for a error code 80710092
is this coming up when you try and log into PS Network?
1helpful
Ps3 error code 80710092
Its a simple but irritating problem which i have too you simply have a bad connection signal to your networking serveryou may need to bring the server closer to the ps3 or you can get a more expensive router(?) of the same type for a better signal
I hope this advice helps, Ben
I cant sign in to my PSN
Hello =)
80710092: You have lost connection with the Playstation network.
1helpful
2answers
80710092
dns error, try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary 208.67.222.222 and secondry 208.67.220.220 this will enable you to go online as for the error code 80710092 i have no idea, im experiancing the same problem. its so frustrating. as soon as i find the answer i will let you know.
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Daniel Dollive
Daniel Dollive
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
