Question about Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A
In the inside bottom of the freezer where the small tray is - a small amount of water has frozen there. It appears it accumulated there from the back inside wall of the freezer. During defrost, the water leaks out the front bottom of the door and spills onto the floor. We pulled the unit away from the wall and there does not seem to be any obstruction or build-up of dust, etc.. Any suggestions, THX WMR
Posted by williross on
2 Related Answers
robert samples
  • 1314 Answers
SOURCE: running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Posted on Feb 20, 2008
ImJustAvg
  • 2006 Answers
SOURCE: Things don't freeze on the
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
Posted on Jun 15, 2011
Why would condensation be running down the sides,or water dripping from bottom?
should be a small plastic tray funnelling from under the fins in back to a small hole n hose out the back of unit check owners manual if possible,..
Jul 08, 2014 | Delfield Freezer 6125XL-S
Kenmore chest freezer - why is there a 1/2 inch of ice in bottom
Hello. If your freezer is not a self defroster, you must have had a power failure for a few hours that caused a melt with water ending up on the floor of the freezer and then refreezing. IF you have a self-defrost model, your defrost cycle produces some water which should make it's way down to the evaporator tray just above the floor... in your case, the small hole in the floor is plugged and the water is accumulating on the floor rather than making it's way to the evaporator tray. The fix is to clean the evaporator tray, defrost the ice with a blow dryer, locate the hole and clean it out with a couple of pipe cleaners or cotton swabs. Regards, Joe
PS please rate my answer. thank you.
Jan 28, 2010 | Freezers
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Water running out the bottom of the GE TFX22JA Freezer section
time for a new thermostat and a new timer
also your vents are probably iced over
defrost and try again
Jul 31, 2009 | Freezers
Frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Apr 07, 2009 | Amana Freezers
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A Logo
179 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
Ismael Rodriguez...
Dennis Boxerman
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
