Question about Nintendo Wii Console
My Wii console will turn on, but no signal is received at the TV. The console powers up, you can load and eject discs into it but nothing comes up on the TV. I tried switching TV's and it still didn't work. The Wii worked fine last week when it was last played.
Posted by as71 on
Sid Schmidt
    Sergeant:
    Champion:
  • 218 Answers
If you switched tvs and no help than that tells you that the cable that hooks the wii to the tv is probably bad try a new component video or rca cable whichever you are using
Posted on Apr 17, 2011
My discs wont load
You could find the manual on the internet by google. Im afraid that it's possible that it possibly broke the disc drive or the part of the drive that automatically loads and ejects the disc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
May 17, 2012 | Nintendo Wii Console
Disc will not eject
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
Aug 22, 2010 | Nintendo Wii Console
When i try to load a disc it says to eject the disc and turn the power off
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Jul 22, 2010 | Nintendo Wii Console
Nothing comes up on my screen
Unplug from wii and wall for 5 mins to reset power block and wii.
Apr 12, 2009 | Nintendo Wii Console
Disc stuck inside Wii Consule
Unplug everything from the system and the power cable from the wall or power strip, let it sit for about 5 minutes. Plug everything into the system first then the wall. Power should come on
If the disc does not eject, contact nintendo, the disc drive will need repair
Mar 15, 2009 | Nintendo Wii Console
Problem with Wii
i think you haven't plugged in the correct RCA cables. you have plug in the yellow, white, and red. or you might not have the RCAs plugged in
Jan 31, 2009 | Nintendo Wii Console
Ejecting Wii disc while power is off
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 29, 2009 | Nintendo Wii Console
Disc stuck in wii console
Your Wii will require Warranty service from Ninteno. However, if you send your unit chances are they won't return the disc.
How to open your wii – http://wiki-scene.com/Wii_disassembly
Once you get to – 'Remove 4 DVD drive screws' Dont do that, just take the 5 screw off the top of the Drive, and the drive will split into 2 and you can easily remove your disc. Reassemble and contact Nintendo for Warranty service.
Dec 15, 2008 | Nintendo Wii Console
Wii disk not ejecting
Jan 23, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
277 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
