Question about Canon imageRUNNER 6020 Copier
IR2520, error code E0002 - Canon imageRUNNER 6020 Copier
Posted by jameshenry00 on
nikhil chachapara
    New Friend:
  • 140 Answers
It is related to fixing unit.
check your fixing unit.
Posted on Apr 18, 2011
  • nikhil chachapara Apr 18, 2011
    you can clear the error by pressing Additional function 2 ,8 additional function then go in clear
    CLEAR > ENGIN > ERRCLR
Error code E000002 in Canon IR2520
Dear
it indicates fixing unit temp could not raised to predetermined value. The following steps may be taken to clear the error.
CLEAR>ENGIN>ERRLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
3.Replace the Fixing Assembly.
4.Replace the DC_CON PCB.
Thanks
Feb 13, 2015 | Canon Office Equipment & Supplies
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Jun 30, 2010 | Canon Office Equipment & Supplies
ERR E0000 & E0002
There are 3 step to repair e0002 error
If you got e0002 error then there is a 94% chance that your computer has registry problems. To repair e0002 error you need to follow the steps below:
* Step 1 - Download a e0002 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair e0002 error.
Here are the url of e0002 error repair tool:
http://www.fixerroreasy.com/ttfix-e0002_error-zz0005
Feb 13, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon imageRUNNER 6020 Copier Logo
2,765 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
