Question about Amana ACS3350AS Gas Kitchen Range
Very hot amana gas range
I have the same Amana model number. We bought ours a few months before Thanksgiving 2006. never used oven until thanksgiving and well we found out the hard way (husband got burned)
that the door latch was defective. It was designed to long and prevented the door from closing properly. Therfor allowing heat to escape oven,making the out side of range as hot as inside.
Sears came to our home and replaced the old part with the new designed one. If you notice your oven getting really hot you might want to call amana and have them replace it more so if you have children or elderly people at home. If they do not want to replace part,please post your matter on this forum. Best regards.
Click on the link below to see if your amana is one af many models which have this defective part.
Leslie Miedema v. Maytag Corporation - Court Documents
  • Nata1 Mar 18, 2009
    I have the same problem with the Amana gas range which I purchased in 2002. Hinges arefaulty and the heatescapes, overheated control panel shuts down untilitcools.
    I do not use the oven often so it took me years to figure out that smth was wrong. During the last few months, my teen daughter got into baking, and the problem showed its ugly face. I researched the problem and went through the postings, but my range is 7 years old......... I called Amana and they refused to do anything about it forfree even though they acknowledge that there was a class action in Florida against Maytag.If I were to report a problem within 48 months after the purchase, it would have been different. Since I bought in 2002, they are not doing anything about it. I need to replace the hinges and the control panel. Any ideas how to make Amana to atl east pay for the parts?
  • Anonymous May 01, 2009
    If you have an Amana range that allows heat to escape from the ranges/ovens when used in their intended manner and is causing irreparable damage to other components or the ranges/oven, including but not limited to, the units’ control board. This problem can discolor the units, diminishing their value and compromises the ability of the ranges/ovens to perform in their intended manner.
    If so, this on going problem poses a significant safety risk to their users and property. I know many of you are frustrated and many of you have complained to Amana and have been told that, “There have been no complaints or that the problem does not exist”. Well they won’t be able to say that any more if the thousands of us come together as one and voice our concerns and complaints.
    If you would like to be heard and possibly have your range replaced or fixed please send me an email of your existing problem along with your units’ serial number and model number and together we will be heard. [email protected]
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: amana over
as far as the elementy working, if it glows red, its working. if the unit is preheating within 12-15 min, id say the elements are fine. as far as not maintaining temp, thats strange, if the elemnt turns on the control is sendinding power, and its shuttin off so its stopping power, sounds as if a relay is geting stuck on the control board, strange thngs happen when you short things out like that.
Posted on Nov 26, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
delpolito54
Dave Del Polito
  • 45 Answers
SOURCE: amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
Posted on Sep 01, 2009
Anonymous
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
Lyle D. Rowh
  • 743 Answers
SOURCE: electric range amana model number AER5515QAW right
It sounds like the Sear's repair person should be looking at the amperage while the burner is in operation...there seems to be an higher output at sometimes.
Posted on Oct 27, 2009
I recently purchased a 4-cup Farberware coffee pot (to replace one that served me well for over 30 years!!) The Model number is FCP with the initial G a few spaces after the FCP. I have had trouble...
Helen,
Fixya is does not sell parts or service, but rather helps answer questions about getting parts and service problems resolved.
You should contact the Farberware website for a replacement cord for your Coffee Pot. Click the "Customer Service" button on the left side of the page, or telephone 1-800-233-9054 for customer service if you'd prefer to speak with someone instead.
I hope this helps - and Happy Thanksgiving to you, too!
Nov 18, 2010 | Microwave Ovens
Gobbles Thanksgiving Hoedown Musical Turkey - 11" - Fun: my smart movie plz tell me licenss key my serial n...
Hello
Unfortunately we are not permitted to provide serial numbers , illegal download links or software to bypass the copyright protection of software in accordance with our terms and conditions and the DMCA copyright laws.
If you bought the product legally you should contact the manufacturer. The contact details should be on the side or back of the box or CD cover.
I hope you understand. Feel free to contact me if you have any questions.
Kind Regards
Andrea
May 18, 2010 | Gund Gobbles Thanksgiving Hoedown Musical...
I used the auto clean & now lock won't open
Try turning off the breaker and reseting the oven.Hope this helps.Happy Thanksgiving.
Nov 25, 2009 | Refrigerators
Admiral oven not heating to setting
No, I'm sorry, you will have to replace your thermostat to get this oven to heat to proper temperature. We are Admiral factory authorized parts and service professionals and will be happy to get this part out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST Monday through Saturday. If you contact us first thing Monday morning, we can next day air this to you so you can have it to cook your Thanksgiving dinner before Thanksgiving.
We look forward to working with you and hope to hear from you soon. Thanks, Ella
Nov 22, 2009 | Kitchen Ranges
Convection oven quit working half way through cooking thanksgiving stuffing
Call us right away with your brand and model number and we'll get the correct part out to you right away in time for Thanksgiving turkey!! We look forward to
working with you.
Oct 18, 2009 | Ovens
Amana Range ARG7300W -- igniter problem back??
I am sure you noticed where it is located. A gas oven cycles the same as an electric. depending on the number of times the door is opened and the length of time you operator the oven. Our furnace was acting up one night last winter and I turned the oven on warm with the door cracked open until I could get the part for the furnace in the morning and our igniter went out on the oven. Also try not to touch the element on the igniter when you install the new one.
Dec 02, 2008 | Amana RanARG7302 Gas Kitchen Range
Keypad is going crazy
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020.
Get help locating an authorized servicer at 1-800-695-0098.
Nov 30, 2008 | Emerson MW8987B/W Microwave Oven
My Amana ACS335AS oven works sporadically.
the amana ACS3350AS control panel is broken, I need to replace it, where can I find it?
Jan 29, 2008 | Amana ACS3350AS Gas Kitchen Range
Unit blows cold air instead of warm (burrrr)
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Nov 23, 2007 | Amana PTC153B50AJ Electric Heat Air...
Amana ACS3350AS Gas Kitchen Range Logo
110 people viewed this question
Top Amana Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
