Question about Pentair Garden
I have a pinhole leak in my pool filter. It is a SD80 tank. Can it be fixed or do i need a new tank?
Posted by ms2651 on
Peter Freese
    New Friend:
  • 56 Answers
If it is only a pinhole it should be an easy fix. First dry the unit thoroughly, the drier the better. Then use superglue gel to patch the hole from both sides.You may wish to smooth the glue for aesthetics just make sure you leave enough so the glue can hold to the interior under pressure. The gel will dry overnight and is non-toxic. Larger holes or cracks would require a plastic welder or applying fiber glass.
Posted on Apr 17, 2011
Not problem with filer, it's the air coming into suction side of pump
try to tighten or lube intake union make sure seal is good then check top seal to pump basket if ok keep checking by turning off skimmers or main drain until ok if still does same you might need new seals in pump has it overheated or ran without water lately
Apr 11, 2014 | Pentair FILTER TANK BOTTOM, 48 SQFT
Purex 4000 filter leaks at bottom
there is a drain plug on bottom see if tight
Feb 07, 2013 | Pentair FILTER TANK BOTTOM, 48 SQFT
Hayward sand s166t. leaking from bottom
Are you sure it is leaking from a spot "Originating" at the bottom? Many times this is what is seen, but the water is actually traveling down the side.
If at the bottom, you either have a cracked tank, or the drain cap is loose, missing the cap gasket or it is on "Cross Threaded"?
But... most likely from experience, it leaking at the valve clamp.
Nov 17, 2012 | Hayward S166T Pool Filter System w1 HP...
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
My pool's sand filter is leaking at the cap. I have tried replacing the cap, but it still drips. Do I need to replace the filter tank now or is there something else I can do to seal the threads?
Put the cap back on and get a two part apoxy that seals leaks more affectionatley known as pool puddy. surround the edge of the lid to the tank. it drys really hard and will seal the leak. use water when combining the two parts . it has the consistancy of play doe but dries like rock. Take equal parts and roll it in your hands like making a hamburger. then roll it and strecth it like thich spegetti and surround the lid against the tank.
The Pool Tank
Jul 07, 2010 | Hayward SAND FILTER, PRO SERIES
Jandt filter leak
it depends, if it's leaking due to a crack on a structural part of the filter such as the tank itself, then yes, the entire tank will need replaced.
Feb 18, 2010 | Jandy PUMP SHAFT SEAL - FITS PUMPS
Water is leaking out of the far right burner tube, while pool pump is running.
sounds like you either have a pinhole in your heat exchanger or possibly a bad tube washer (seal). A pinhole can result from poor water chemistry or chemical exposure such as pH chronically low or a chemical feeder (chlorinator or salt cell) installed near the heater without a chemical resistant check valve. You will have to dismantle the heater far enough to access the heat exchanger and inspect it while the pump is running. If it's a pinhole in the exchanger, you will need a new exchanger. If its a seal, you will just need a new set of seals (washers) for the exchanger manifold.
Sep 23, 2009 | Pentair Minimax NT Heater
Gash and pinhole leaksin copper tubing in pool heater
None that last very long. A new exchanger and keeping the chemicals in check moving forward is your best bet.
Of course you can try to have a radiator shop fix it but I have had mixed success with those and it seems to depend on how much of the remaining copper is thin and/or damaged but not leaking yet.
If you would like a quote on a new exchanger, contact us at www.arrowpools.net with you model number.
Jul 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
There is a small crack in the pump housing and it has created a pinhole size leak. Is there a way to fix this, or do I need to replace the housing?
Ideally you will need to replace the wet end (not the whole pump) but there are products like LS-X made by fernox that will seal such a leak.
Jun 29, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Garden Logo
1,734 people viewed this question
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Pentair Garden Expert? Answer questions, earn points and help others
