SOURCE: Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
SOURCE: no driver for the scanner hp officejet 9130 all-in-one priter
You obtain the driver the for HP office 9100 series, here.
- it is on purpose that I want you to download the older PCL5 driver, asthe new PCL6 can course problems.
If any problems, against all ods, should arise, do write back and I will be here to help you.
Regards
/Teis
SOURCE: HP officejet pro 1170c drive cd instllation for win VISTA
hello
you can download the drivers from http://www.techspot.com/drivers/driver/file/information/7589/
please check let me know
SOURCE: HP Scanjet 5300cse, setup.exe file will not run using windows XP
Whats your hardware.
Try this solution...
Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&cc=us&dlc=en&product=58381&os=228&lang=en
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
SOURCE: how can i add an HP printer officejet pro L7580
All the software/drivers for your HP printer can be installed by clicking on the link below:
Just select the OS you use, and you are good to go for the free download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=2512008&#
