SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
SOURCE: will not blow cold air
If your room is not getting cold enough when your A/C is turned on, It is time for a good cleaning. There are a variety of factors that may cause your A/C to not cool your house. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causes as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, if need be, take advantage of the text-link for free four (4) quotes and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern what could be the problem.
Posted on Jul 13, 2009
SOURCE: LG 24000btu not blowing cold air. Fan runs but i
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Posted on Sep 04, 2009
SOURCE: Chilled air flow is changing to warm air flow
Sounds like a classic floating restriction. An A/C unit with a leak on the low pressure side can **** in moisture which is then pumped through the system, as it goes through the metering device, typically a capillary (very thin) tube, it freezes, creating a blockage. The discharge air warms, the ice melts and circulates again. During the circulation, you get cool air.
The problem could also be electrical. A faulty overload device or the compressor in the process of failure, could give these symptoms. Best thing to do is shut it off and have a pro take a look. If it is a window unit, look for a local refrigeration school to check it out. THey will often do the repair for the cost of the parts.
Posted on Jul 19, 2010
SOURCE: my LG portable AC won't
I have searched all LG data bases for the Model Number(s) you listed and those numbers were not found.
Please recheck the model number and get back to me. So that I can try to help you, again.
Thanks, Rich
Posted on Jun 10, 2011
Sep 21, 2018 | LG Heating & Cooling
Jun 06, 2014 | LG Electronics LP0910WNR Portable Air...
Sep 13, 2011 | LG Heating & Cooling
Sep 13, 2011 | LG LP0910WNR Air Conditioner
Aug 05, 2011 | LG LP0910WNR Air Conditioner
Jun 10, 2011 | LG LWHD1000R Portable Air Conditioner
Sep 03, 2009 | Everstar Portable Heater/Fan
4,669 people viewed this question
