Question about Dometic RM2652 Refrigerator
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
Posted by wdw8571 on
richardsetze
    New Friend:
My domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Posted on May 15, 2011
Domitec fridge will not cool
Have you tried it on electric?
If the fridge is level, and the rear coils of the fridge are warm and the fridge does not cool, you will more then likely require a cooling unit. Arcticold refrigeration manufactures brand new replacement cooling units that are available throughout north america Visit ArctiCold Refrigeration We keep it cold
Feb 16, 2014 | Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic RM 3662 not working on gas or AC power. I've changed the heat element, I can see the flame of the burner. What's going on that the unit won't cool off. Tried gas for 5+ hours and the fridge seemed...
When running on Electric insure that the rear coils of the cooling unit are getting warm. If the refrigerator is level and the coils are warm and the refrigerator does not cool then you more then likely will require a replacement cooling unit. I have attached a small video that may help with the diagnoses. You can also give us a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold
Aug 27, 2013 | Dometic Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
I have a dometic rm2820 up right fridge on bottom freezer on top. the freezer gets really cold but the fridge part stays warm.
Did you by chance recieve a recall from the manufacturer .? we got one about two years ago we had the same problem, they fixed it because there was danger of fire, i would contact them
Jan 19, 2012 | Dometic Refrigerators
My unit works great on AC (cools to 30degree), but
Your fridge has two manual settings to adjust it's internal temperature. Obviously, it most likely has a standard control (1-5 or 1-9 depending on the fridge) that you can adjust on the control panel. Some fridges are preset (no control panel adjustment) and must be adjusted on the inside of the unit. If open your fridge, look at your cooling fins. You will notice a metal slider on a wire attached to one of the fins. Moving this sensor up or down along this fin will set the internal temperature of the fridge. You will have to play with it a bit to get it set properly (with a thermometer), but you should be able to get it to the proper temperature. I hope this solves your problem. Thanks... John Charles
Jun 12, 2010 | Dometic RM2652 Refrigerator
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Dometic RM2652 Refrigerator Logo
1,241 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Paul G
Paul G
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
