either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
31 sounds about right for a sierra and the clock settings are in the menu. Hit menu then you have a small round knob to advance the hour or you have two small buttons in the lower right hand corner of the radio.
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
