Question about Sharp Wizard OZ-650PC
Can you renew functions of some of the now hard to activate keys on my Sharp Wizatd OZ-650 and also transfer my data that I have in it to my newer OZ-770 and replace the 770 screen? The sceen has deterirated in storage and has verticle blank lines running down the screen. What would be your estimate? Can you do it by overnight receiving, repair, and return?
5 Suggested Answers
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 06, 2008
Charles Klaus
  • 10 Answers
SOURCE: Sharp Wizard OZ-770 working with Windows Vista
The www.wizardshop.net
can help you get it working with vista 32bit.
Go to www.thewizardshop.net and email or call them.
Posted on Mar 03, 2009
Anonymous
Here is a link to the manual
Posted on Mar 25, 2009
Anonymous
SOURCE: Syncronizing the data from a Sharp OZ-650 to a new computer
Just get a USB-to-Serial adapter and use the same method you used to use. Here's the one I ordered and it works fine. It includes a CD for loading a driver which I loaded before plugging anything in.
http://sewelldirect.com/usbtoserial.asp
Posted on Sep 14, 2009
Have purchased recovery dics for my Hp TouchsmartIQ772 following massive crash! All hardware checks out fine apart from CD rom drive! Ihave loaded all three discs on my external hard drive but am unable...
Are you able to boot from CD?
When booting PC, press the Function key that lists the 'boot from' options.
Sometimes this is activated by the DEL key.
Jan 12, 2011 | Computers & Internet
Sharp oz-770
Have you tried transferring with the original software for the device? Here is a page with download links for the original software, also here is a free trial software that claims it can transfer this data.
Jul 16, 2008 | Sharp Wizard OZ-770
Hi Pat,
May 04, 2008 | Sharp Wizard OZ-730
My computer is not accept current Norton renewal
You don't need to install the renewal only need to activate the existing Norton pogram with the newer product key
to activate click on express renewal and enter the renewal code. also you can download the latest version from this link at free of cost : www.norton.com/nis10
May 19, 2010 | Symantec Norton Internet Security 2009
Touch screen not functioning
Please see this link. Most likely uou have one of the newer SHARP touchscreens that is known to fail prematurely.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Dec 15, 2009 | Garmin nuvi 650 GPS Receiver
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
Forgoten password
If you forget your password, there is no way to bypass the Secret function or enter a new password without losing all data marked as Secret.
If you forget your password, you will not be able to
unlock the Organizer and access your secret information. If this happens, you will have to delete the old password to be able to continue to use the Secret function. This will also delete all entries marked as secret.
The instructions on how to do this are here Page 56:
http://74.125.93.132/search?q=cache:SOGXtoq14ZkJ:www.sharpusa.com/files/org_man_OZ730_750.pdf+Sharp+Wizard+OZ-730+recover+password&cd=1&hl=en&ct=clnk&gl=ca&client=firefox-a
Oct 25, 2009 | Sharp Wizard OZ-730
Retrieve Password without losing data with Sharp Organizer
According to the YO-370 Operation Manual:
What To Do If You Forgot The Password -
When you have forgotten the passord for the SECRET function, you have to delete the password along with all secret data by selecting "DATA DELETION" from the Function menu. Once the password is deleted, a new password can be entered. Follow the procedure below to delete the password (and the secret data along with it).
1. Recall the Function menu (2nd, FUNCTION)
2. Select "3 DATA DELETION", and press v (3, v)
3. Select "3 SECRET DATA". (3)
The delete prompt "DELETE ? Y/N" appears
4. Press Y (To retain the data, press N)
When Y is pressed, both the password and the secret data are deleted, and the initial display for the previous mode in use will reappear on the display.
Mar 23, 2009 | Sharp Wizard OZ-800
A quick and dirty method of getting your data to near flat file format is to find a computer with the old RS-232 serial port and use a third party software called "Rupplynx" v 6.0 or 6.1 to download the data from the Wizard to the Rupplynx software on the PC. The backup/extracted files that you create with this software will be binary but the address book, memo etc data portion of the file will be ASCII text that is readable (beware, even the secret entries are readable so you will have to guard the computer that the files are on). A better but slower way is to copy and paste the uploaded and displayed data text in the Rupplynx 3rd party software to a Word document or plain *.txt file. I did this for the most important data since I also had about 10 years worth of memos and contacts.
I copied the whole subdirectory with the binary files from a windows XP computer that had an RS-232 port to a Windows vista computer and the program ran fine so that I could get the data into a compatible format such as Word or plain text file format. (via copy and paste) Rupplynx also has an export option to export to different file formats...
Oct 24, 2008 | Sharp Wizard OZ-650PC
Sharp OZ-630
Do an ALL RESET. The only way i know of to do it is to hold the ON and Reset at the same time. Then select yes at the promt. Then wait 2 mins and take out batteries. Reinsert and turn on. it will re-format. This is the only way i know of how to ressurect it, but it deletes ALL you data.
Thanks
Aug 18, 2008 | Sharp Wizard OZ-630
Sharp Wizard OZ-650PC Logo
78 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ekse
Siul Oyaratgam
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
