The Model number is GT4175, about 3 years old , do not use much only for heating food. The problem just started when I push the strat button, I hear poping noise then smell somthing is burning ( like burning wire ).
Thanks for your help
It does sound like a relay malfunction or similar switch. Could be repaired but call for a quote or better yet, take it to a repair depot (probably cheaper).
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
This model is a lower-end type that probably didn't cost very much. Since it's over 2 years old, you have no warranty left. Most appliance repair shops charge extra $$ for servicing installed items in the home. You'd probably be better off purchasing a new comparable model. The labor fee alone might equal what you paid for it.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Most common problems for no heat are bad magnatron, diode or capacitor. With the high voltage in play you should have an experienced technician check it out. Check your owner's manual because some manufacturer's give 5-7 yr. warranties on the magnatron.
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
