When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
SOURCE: Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
SOURCE: why does my front loader washing machine bang
it is either out of balance from over loading or the center rotorey bearing is bad ,,most likely problems
SOURCE: banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
