Question about Sansui Audio Players & Recorders
I have an old but very good Sansui system that is all compu linked. The amplifier is a A1200P Integrated DC Stereo Amplifier. Unfortunately, it appears that the left hand channel output is faulty there is very little volume and it is severley distorted. I have checked the speakers and they are ok. I was wondering if anyone out there can help. My email is [email protected] or telephone 07970763202. I am located in Weston-super-Mare England
Posted by cliversmith on
5 Related Answers
Anonymous
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Posted on Feb 01, 2007
robotek
Graeme Ross
  • 1512 Answers
SOURCE: JVC AX-33 Stereo Integrated Amplifier - very little sound!
Hi xaser
Check that someone has not turned on the tape monitor or mute. Both of these may cause the problem. Is there alot of noise with the sound you are getting when you turn it up?
regards
Graeme
Posted on Mar 22, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: I have a Sansui AU-717
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
Posted on Apr 13, 2008
robotek
Graeme Ross
  • 1512 Answers
SOURCE: My Marantz PM-45 integrated amplifier
Hi HouseofBlues
The problem you are facing is the speaker protection is turning on to prevent the amplifier from damaging your speakers. It will need some service work done to it to prevent it from happening. I suggest you get it attended to sooner than later, as the problem will be caused by dry solder joints that will need to resoldered, or a semicinductor that is failing. If you are a gun with a soldering iron, you could do this yourself. Check about parts of the amp that runs hot, particularly transistors and resistors in the output stages. resolder all output transistors, and any parts that are mounted to a heatsink. Also focus on areas of the PCB that has discoloured. This is often where the problems occur.
I am more than happy to answer any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 02, 2008
Anonymous
  • 51 Answers
SOURCE: Center channel speaker output problem
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Posted on Jan 08, 2009
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
No output sound on one side (L) from Integrated Amplifier
Actually I think you are looking for an STK4204 MK5. I would search google for where to get one, depending where you live.
Mar 01, 2013 | Audio Players & Recorders
Kenwood Stereo integrated amplifier A-58
hi i have bought kenwood hi fi with following parts -
integrated amplifier - A-58
cd player - DP-M58
stereo receiver - T-58L
twincassette player - X-58
turntable - P-38
but I can't get owner manuals from anywhere. Can you help me with it please ? [email protected]
Jun 29, 2012 | Kenwood Audio Players & Recorders
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
The volume will not turn down
Do the volume controls on the stereo itself (not the remote) work? Try using a universal remote to lower the volume.
Dec 28, 2008 | Teac Audio Players & Recorders
I have a Sansui AU-717 Integrated Amplifier that needs some work done on it. Is there a Sansui service center in Washington State that can work on this?
Sansui:
Jerry G.
Apr 13, 2008 | Audio Players & Recorders
76 people viewed this question
Top Sansui Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
