There is a problem with the cardrige.
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
the only thing you can try is: uninstall the printer drivers from your computer using the Control Panel, Programs and Features, Samsung Printer uninstall, after this you have to reboot your computer and now install the drivers from the samsung cd aggain to your computer, if this is not help you might contact a samsung workshop!
Hallo Sir,!
PRINTER STARTING PROBLEM---DONT WANT TO READY:
Very thanks for sending solution , but its does not help, i try to put command but key board not working, when start First time its take 6 minut to starting, then each 7 second main Moter starting to ready but faild,always showing on display -warming up please wait-Please send another solution if possible.
Regards,Jann
