Question about Zenith XBV443 DVD Player/VCR
How to get it off progressive scan mode - Zenith XBV443 DVD Player/VCR
Posted by awadedk on
Demonic-2011
  • Zenith Master
  • 513 Answers
As with Goldstar and some JVC machines, the way to get progressive scan OFF is to do this:
with the unit on, but no discs inserted, on the front panel (not the remote) press and hold STOP button for 10 seconds, then release. This should revert the unit's video output back to normal interlace and switch progressive off. I hope this works for you.
Posted on Apr 16, 2011
My zenith xbv343 dvd vcr combo has a problem when i put on a dvd it says progressive scan mode i cant see nothin else
Hello
That means the DVD you put into it to play has recordings with "progressive scan" mode. You have to change the mode of the DVD and TV which you wants to see to Progressive Scan mode to see the disc content. OK.
1helpful
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
hi,
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
ok
2answers
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
4helpful
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
3answers
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
13helpful
4answers
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
8helpful
2answers
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Interlace Scan (IS) mode and the Progressive Scan (PS)
The Interlace Scan (IS) mode the camera uses a mechanical shutter with shutter speeds up to 1/640th second. It also uses the maximum resolution that is possible with the CCD (5.0 MP). In the Progressive Scan (PS) mode the camera operates with the electronic shutter with shutter speeds up to 1/4000th second and a 1/18000 second shutter speed (1/18000 in Shutter or Manual Priority modes only). In this mode the resolution is reduced in half (2.5 MP).
Zenith XBV443 DVD Player/VCR Logo
Top Zenith Televison & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
