Question about Sharp HT-DD5000 System
How can i get all of my speakers working at the same time with my sharp ht dd5000?
Posted by spsanch89 on
Mark
    Master:
  • 403 Answers
You cant, its a surround sound unit. It shoots sound to speakers when called for.
Posted on Apr 16, 2011
I just bought the sharp home theater system ht-sl70/ht-sl75 and I cannot get the volume to be controlled thru my remote. I have a 60 inch sharp aquos tv. It has no arc and when I use the rca connection it...
Hi
I just bought HTSL75 speakers. Its manual saying its volume is controlled by TV's remote control
But i am having Samsung UN46EH6000 LED. and Speakers is connected to LED via RCA and LED is giving fixed output, so all the time, speaker is working on full volume
Is there any workaround, so that i can control volume while using sharp HT-SL75 speakers with Samsung UN46EH6000 ?
Is there any volume control device to control the volume of the speakers in my case ?
Thanks for your help !!
May 09, 2012 | Sharp Audio Players & Recorders
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp HT-DP3000 reciever don't know how to plug in speakers
Hello, many thanks for your request. I found a quick manual for HT-DP3000, you can download it here:
http://www.tradebit.com/filedetail.php/9120914
(Check out for the green download button on the upper left side)
Aug 31, 2009 | Sharp HT-DP3000 System
Don't know what to get for sharp ht-dp3000 home theatre
Aug 19, 2009 | Sharp HT-DP3000 Shelf System
Sharp DP2500 speaker bus diagram
Hi..have you gotten an answer for this question...I just googled this model number..and about the second one down is the factory service manual...for the model you and I have...there is a way to go inside and solder wire to each speaker leg to make it work that way without the special plastic connector that was the original..
Apr 05, 2008 | Sharp HTDP2500 System
Pioneer MX5600D
Sounds to me like something burnt, maybe a fuse, Capacitor... Without opening it and running test it would be hard to determine the exact source of the issue. If you are using a power bar try it without.
Feb 04, 2008 | Sharp HT-DD5000 System
Sharp HT-DD5000 System Logo
82 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
