Question about Panasonic PV-C1352W 13 in. TV/VCR Combo
Panasonic with blue back ground on the screen of my TV !
The TV has a blue back ground that fills much of the lower half of the screen, the first thing is says is PANASONIC the it slowly continues to discribe fetures of the TV, almost like some kind of DEMO screen you might find on the show room floor? My nephew was playing with the remote and this is what he left me with.... I've tried everything I can but can't get rid of it.
Help?
Thanks
Dit.
Posted by datus on
  • Anonymous Apr 08, 2009
    Panasonic TV setting: what is Flicker Reduction and Blue Back?
5 Related Answers
Anonymous
SOURCE: dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Posted on Apr 19, 2008
Anonymous
SOURCE: panasonic omnivision tv/vcr combo
I had the same problem, and i found the solution!
If your using Comcast universal especially, try this code: 0250
it works perfectly, u wont be able to turn off and on TV, but u will have volume and Line to cable control just fine
W000T!
Hope this helped you!
Posted on May 04, 2008
Anonymous
SOURCE: remote codes for verizon fios universal remote
The code that worked for us was 3223
Posted on Sep 14, 2008
Anonymous
  • 3 Answers
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Dec 30, 2008
Anonymous
SOURCE: the screen keeps flashing a
Press and hold the Play / Repeat button on the TV. It will beep and give you some message about inserting a cassette. Just hold the button for a few seconds. Should do the trick. Worked for me.
Posted on Nov 23, 2010
Panasonic TX-P42521B has a red/blue band across the screen (about2" wide) which is flickering and about 2" below is a broken red line. Any ideas? Thanks.
These symptom seems to be caused by a
defective D or SC board but in reality, they are
caused by a defective SD board.
To confirm this, disconnect the SD board from
the SC board (Follow proper SU/SD board
If the SD is defective, the screen will have a good picture at the top half of the screen and a completely black area in the lower half of the screen.
R
Jul 21, 2014 | Panasonic Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Half the screen is filled with lines?
If within guarantee, let shop repair. If in guarantee,to open will invalidate.
Jan 27, 2013 | Panasonic Tc-p50c2 50-inch 720p Plasma...
Hi, I have a F & P top load washer (model GW701-U) over 10 years old. I use cold water washing. The water fills up very very slowly- just dribbles. After about 7 minutes of the water filling up, the...
Turn off the water to the washer, unscrew the hoses ( do one completely before moving to the other)Once you unscrew the first hose you will see a small filter screen inside the opening on the washer,Remove the screen and clean it, replace it and reattach the hose,Now go to the other hose and do the same thing, once both are done and hooked back up, turn the waterback on and everything should work as normal.
Dec 02, 2010 | Fisher and Paykel Washing Machines
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Panasonic PV-C1352W 13 in. TV/VCR Combo Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
