Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Door has worked fine for years with a Schalge camelot electronic lock. Tonight it stopped working and you could not open the door with the inside or the outside handle. Key would not open door either. I removed the inside panel and replaced the battery, but it did not fix the problem. We cannot use that door at all not and I cannot disengage the door lock. What can I do?
Posted by foleyde on
Coaltowner
  • 963 Answers
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Apr 16, 2011
The door will not lock. Inside handle acts freely when lock is engaged. I have changed battery with no luck. Any suggestions?
The inside handle will always open the door whether it's locked or not. This is a safety feature. If it locks from the outside then it's working as designed. Might help you to watch this video.
http://consumer.schlage.com/service-support/pages/instructionsandmanuals.aspx
Feb 28, 2016 | Schlage FE595VCAM716ACC Camelot Keypad...
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Apr 30, 2014 | Cars & Trucks
Schlage deadbolt
Olathe, KS 66061
You also need to check the operation with the door open versus the door closed--to make sure that you haven't developed a mechanical bind between the door and doorjamb. If all else fails, the lock should be under warranty!
Jan 26, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
My code has been working just fine, but... just
Follow the installation instructions, paying particular attention to step8- the door handing instructions. You probably have it backwards:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Jan 25, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Keypad indicates green but does not unlock door. Neither does the inside knob. Key opens door. New Battery.
Olathe, KS 66061
Jan 20, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Somehow the lock thinks that when the door is locked it is open, and when it is open, it thinks that it is closed. Did I somehow put the lock on in some reverse order? Or can I somehow program the lock...
Take the lock back off and flip the back portion of the lock so the locking lever is reversed you have that on backwards. If that doesn't work reset the lock back to factory settings and reprogram the lock!
Aug 11, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
The trunk release (both on the door and on the key fob) stopped releasing the trunk lock on my 2002 Saab. The only way to open the trunk is through the emergency release pull inside the trunk. Is there a...
If the fuse is okay, check to see that the latch is not bound in some way, and that it is properly lubricated. A dry latch sometimes will not release.
Nov 02, 2009 | 2002 Saab 9-5
Schlage deadbolt simply failed to unlock, with key from exterior and from inside latch. The feel was like there was no resistance. The lock is only one year old and a previous Schalge deadbolt failed after...
you can buy some "grafite" powder at lowes that is made for stiff locks, it will grease it up. if that doesnt do it the your problem may be in the plunger. might it be out of line? if so straighten it and make sure the it aligns with the strike plate on the door jamb. one of those are sure to fix it.
Apr 17, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
2005 Cadillac STS door problem... Front driver door wont open from outside, seems as if the electronic system isnt responding to release latch when handle is pulled? Anyone have similar problem? All other...
There is NOT a mechanical connection to the outside door handles on the front doors. There is an electronic "door popping solenoid" This is a electronic problem. I think there was a recall on this.
Apr 05, 2009 | 2005 Cadillac STS
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
989 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
