SOURCE: Can I reset the HDD1 user password on Toshiba satellite?
If the password was set on the hard disk from the laptop that it was install on, then you can reset or remove the hard drive password using the BIOS configuration, you need to enter the existing hard drive password to this.
There are no back door paswords available, if you ca't remove the password then the drive is useless. This protection is use to prevent unauthorized access to data stored on the hard drive.
To get the laptop operational again you need to replace the hard drive and install Windows again.
FixYa is a free service and advice is given freely by its members but for some services there is a charge.
SOURCE: I have forgotten bios password of my pc (Toshiba
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.
But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.
Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
