Question about Maxtor OneTouch III TURBO EDITION 1000 GB Hard Drive
Maxtor Hi Troy, My name is Michael and I read your thread about the Maxtor problem you experienced.  I believe that I have encountered the same issue, and was wondering if installing the drives internally into your computer has worked well for you.  I have an Apple G5 and was hoping I could do the same.  I don't even know if I have slots for the drives, and is it something that I could do easily myself.  I'm sure you are busy, but would appreciate your input.  Look forward to hearing from you when convenient. Thank in advance. Michael  ([email protected])
Posted by michael08sch on
5 Related Answers
RAS037
SOURCE: Opening external drive case
Actual solution. The darker side panels pop off and they alone hold things together. Simply pry each side away at rear. That would be end with power and USB connections are.
Posted on Jan 16, 2008
Anonymous
SOURCE: Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
Posted on Jun 25, 2008
Anonymous
  • 29 Answers
SOURCE: I have a maxtor icon with a lock on it. I click on "unlock" and nothing works
Have you tried right clicking on the drive and going into properties. Click on security option and make sure that all the permissions for the drive are active with the exception of special permissions. Also look at the advanced security settings and make sure that you have full control permissions. Hope this helps.
Posted on Dec 10, 2008
TIPS72
DUSHYANT SINGH
  • 369 Answers
SOURCE: Can't access Maxtor Manager on 250GB Maxtor Basics portable USB
ANY WAY I WOULD JUST LIKE TO KNOW WHY U WANT TO USE MAXTOR MANAGER..
IF U JUST WANT TO WORK WITH THE HARD DISK U CAN GO TO DISKMANAGEMENT AND INTIALIZE THE HARD DISK AND IT WORKS NORMAL IF U NEED THE MAXTOR MANAGER JUST TRY TO FIND THE APPROPRIATE ONE FRO THERE SITE WHICH MATCHES YOUR HARD DRIVE MODEL.
GOOD LUCK
Posted on Jan 04, 2009
Crankstart
Chris
  • 696 Answers
SOURCE: Maxtor One Touch 4 won't open
Hi, Generally one of three things will have happened, They damaged the cord, broke the connector inside the drive or they shorted the board by bending the connector. In the first case you can replace the AC adapter. In the other two cases it's not generally worth repairing due to cost. You can try locating a connector with the same voltage amperage and polarity to test the drive but you simplest solution in all three cases is simply to purchase a new enclosure at the local PC store and have the techs put the harddrive from the maxtor enclosure in the new case for testing(about $40). If this works you're done. If not the short may have damaged the cicuit board on the HDD. If the drive itself is damaged and you need the files that are on it you will need the help of a pro. Try the above suggestion and comment back here as to your results, if you need a pro, include your country and city in the comment and I will make an appropriate recommendation. Chris
Posted on Jun 05, 2009
Maxtor Personal Storage 3200, after years of use my Vista machine now tells me that the USB Device isnt recognised.
However last month I found that the Maxtor is no longer recognisable to my machine. Reading through related postings on other sites it appears that Vista updates from Microsoft may be the reason why this functionality has suddenly ceased. I presume the security updates in particular may have meant that the Maxtor 3200 is also considered a potential threat. The question is who will take responsibility for resolving this issue of Maxtor 3200 users no longer being able to access their back up files via their Vista based machines. Personally I believe the onus is with Microsoft
hope this helps
John
Feb 24, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Files saved on the maxtor hard drive become read only. I cannot make changes to the files and save it.
The cause of read only files are the files open by other network. To fix this problem copy your files and save it again to your computer. Or you may open the files and save it again in different file name.
Mar 26, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor 3200 cannot find file
You might have to uninstall, and reinstall your game, if the program files can not be located
Jan 11, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I believe that my maxtor external hard drive may have gotten password locked, it shows in my hardware properties, but won't reconize in windows.
it could also be a hardware issue.... i make alot of money from recovering data off maxtor drives that are not recognized by the bios or in windows.
Robert
Sep 07, 2008 | Computers & Internet
Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Jun 08, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor not able to connect
A VIRUS INFECTION OR A TROJAN IS STRONGLY SUSPECTED..
THOUGH MANY ANTI VIRUS MAY NOT PICK UP
KASPER SKY INTERNET SECURITY HELPS HERE TO REMOVE THE INFECTION
SO INSTALL TRIAL VERSION OF KASPER SKY INTERNET SECURITY.
Dec 24, 2007 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor OneTouch III TURBO EDITION 1000 GB Hard Drive Logo
Top Maxtor Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Lucky
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
