I have a Thomson Scenium TV APO410281. This is an old TV I know but has been fine up to now. I turned on the TV and the picture is concave Left and Right. Top to bottom is ok. Also it seems like the picture has been enlarged because I can no longer see text on the screen in SKY or when I change channel eg Normaly I can see AV1, All I see now is 1. Viewing program information on SKY, both edges of the box are outside the frame I have tried changing the picture formats but nothing works I still see the concave edges Left and Right. I think the answer may be a new TV! Grateful for any help.
    New Friend:
  • 3 Answers
Have you tried changing the VIEW Mode on your remote from ZOOM to Normal. Might Help.
Posted on Apr 16, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
Anonymous
SOURCE: THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Posted on Jun 08, 2008
Anonymous
SOURCE: Small black box in upper left corner of Sony TV - need to remove
I had a similar problem on my Toshiba Regza but trying my fix couldn't hurt. I use a satellite dish for TV (if you do the same this might work)... I turned off my receiver, took the programming card out, cleaned it with my shirt (especially the part that looks like a computer chip), put it back in the receiver, turned it back on and when everything reinitialized the black rectangle was gone.
Hope this helps.
Posted on Apr 13, 2010
Anonymous
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
COLIN
  • 182 Answers
SOURCE: MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Posted on Jun 03, 2010
Thomson scenium 30lcdb03b manual
this tv is old now and thomson no longer have them in stock
the menu on the tv is very good and should cover all conections and inputs and tunning
Jan 07, 2012 | Thomson 30LCDB03B 30 in. HDTV
Hello, I have a 52"
you do not give a model. is the tv plasma, rear projection or lcd as they have different ways of lighting the screen so i can not advise further
Aug 26, 2011 | Thomson Televison & Video
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
http://cgi.ebay.com/LAMP-THOMSON-SCENIUM-61DSZ644-RP-HD-DLP-TV-/270697798709?pt=LH_DefaultDomain_205&hash=item3f06d89c35
Mar 09, 2011 | Thomson 61DSZ644 Rear Projection Lamp...
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
Jul 13, 2010 | RCA Scenium HD65W20 65" Rear Projection...
My thomson scenium goes straight to standby when i turn it on. it was working fine, and i turned it off on the set itself. nothing works using the remote either
Tries by reset it unplug and replug,clean ur IR in ur remote and change the batteries,also clean IR in the tv also.
Oct 22, 2009 | Televison & Video
Feb 08, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Thomson scenium rear projector 52inch
What is your tuner source? Cable, Satellite, or antenna?...accordianman
Nov 17, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
