Question about Mitsubishi VS-60609 60" Rear Projection Television
I have a vs-60609 60"
Posted by tim_warner on
Anonymous
    New Friend:
  • 77 Answers
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Posted on Apr 15, 2011
MAGNAVOX DOES NOT TURN ON
chirp is short in power supply/sweep board===usually one in middle with large red wired black transformer.
Aug 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
I have a mitsubishi vs 5059, when i open the TV I get a black square covering most of the tv but i can hear the sound and also see the picture outside of the black square. I don't know if there is an error...
You can likely buy a replacement remote here:
Remotes.com
'Universal' remotes exist only in your dreams; there is no such thing since the manufacturers cannot agree on a basic code set that would work with any set. None of them can control every function of every brand and model made.
Sep 27, 2009 | Mitsubishi VS-5059 50" Rear Projection...
HAVE 56 INCH PANASONIC REAR PROJECTION--LARGE BLACK SQUARE RIGHT IN THE MIDDLE OF THE SCREEN
Hello MCNJC,
Get your remote and go to the close caption in the menu or the CC button on the remote. Set the close caption to off, or set it to CC1 to see close caption. NEVER set it to TEXT 1 or any TEXT at all.
Best regards
circuitcity
Jun 22, 2008 | Panasonic Televison & Video
Black square
Black square in the middle could be closed captioning. Light engine is approx. $700 to $1000 for the parts alone. Time consuming job to change - 2 hours - so expect a hefty labor charge as well.
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
What is this?
either your lens is defective or its the light engine
Repair of a Mitsubishi TS-4553 46" rear projection television
I checked out past posts on your forum and found the answer there. The TV is working great. I did have a bit of trouble finding the cc in the menu, but finally found it and the problem was solved by turning the cc off. Now I just have to make sure that they don't turn it back on!
Thank you!!!!!
Feb 18, 2008 | Televison & Video
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Black square in the middle of my viewing screen.
you have accendly turned on closed caption. the closed caption you have tured on is not the normal closed caption we are used to . it is called colsed caption text. either on your remote or in you manu, find the way to turn off cc & you should work ok. good luck.
Jan 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
