Question about Sony XM-2150GSX Car Audio Amplifier
I have an XM-2150GSX 760watt sony amp, ive gotten everthing hooked up to it, but for some reason i have power to the amp but not to the subs, i know the subs are good still (i hooked them up directly to the stereo) what would cause this to happen? i think it might be the blue remote turn-on wire, but im not sure (i might not have it spliced into the correct wire?) any ideas?
Anonymous
    Scholar:
  • 146 Answers
If you are hooking 'blue wire' (remote turn on for amp) to the power antenna wire (usually also blue) from the radio that could be your problem since the antenna only gets power when the radio is used
try using the switched 12 volt wire you used to connect your stereo power
i will assume all other wiring is correct and if so this should fix your issue - if not write me back with as many details as you can about how you have things wired and i will try to help more
good luck!!
Posted on Apr 15, 2011
  • Anonymous Apr 15, 2011
    alright, ill give it a shot later today. im sitting in class right now haha.
1helpful
Overcurrent lights comes on whenever my amp is on
this can only mean 2 things, either your over working the amp, which means your amp is trying to push power that it don't have, and it's getting hot which is known as thermal mode. and the other reason can be that make sure amp rms. matches the rms. of your subs.
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
I have Sony XM-2150GSX amp on offset cant get it off
check for a short on one of the edges or a resistor on the edge of the board
Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Subwoofer Wont Work
If the connections are correct...?
then it doesn't sound like theres a problem with the amp.
make sure the amp is not to powerful for the sub?
eg: 1000w amp, 500w sub.
Sounds stupid but it happens.
make sure the gain / volume is not too high!
if your BMW has a totally sealed, metal boot area this doesn't help.
My sony xplod XM-2150GSX amp has a problen whenever i turn up the volume on my radio the amp turns on the current overload LED cAN enybody help me out i opened it but i just cant seem to find the problen...
Often this is related to speaker wiring. Make sure your speakers aren't below the minimum rated impedance for your amplifier; 2 ohms per channel, or minimum 4 ohms in bridged mode. If you have two 4-ohm subs, you can't run them both in bridged mode if they're wired in parallel. If you have a blown sub, it can cause this problem also.
Sony XM-2150GSX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
