Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Fan works but compressor does not kick in, therefore does not collect water. temperature and humidity in basement : same as before
Posted by l_gamache on
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on May 27, 2011
Whirlpool AD70USR0 Dehumidfier - Our basement is extremely humid and the dehumidfier sounds and looks like its running but collects no humidity...any suggestions why?
If it is very cold some of these consumer units will not turn on the compressor. If the unit suddenly stopped working and the temperature is room temperature I would guess a refrigeration issue- either a leak or bad compressor. Make sure the "full bucket" indicator light is not on- the condensate bin may not be plugged into the unit properly.
Sep 25, 2011 | Whirlpool Dehumidifiers
I've been reading the other questions on this website. Like many others, our 54501 dehumidifier turns on and all controls still work. We just cleaned the filter but it does not collect water. I read...
No, it may mean that you don't have the humidity extraction level set low enough. The lower the setting, the more humidity it will extract. Try setting the extraction level at 35%, to see if the compressor turns ON.
If yours is being used in a basement, the ambient air temperature at floor level is between 40 - 60 degrees. Dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air temperature at floor level is colder than at shoulder level in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
I hope this helps you further troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 25, 2011 | Kenmore 54501 Dehumidifier
My dehumidifier compressor kicks on fan runs the front cooling unit is cold and appears to start collecting moister 12 hrs later maybe it collected at the most half a cup. Is this something I can fix...
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem. Thanks for using FixYa.
Jul 22, 2011 | Kenmore Dehumidifiers
The dehumidifier does not collect any water, the fan is running and I can hear the compressor kick on and briefly run 10-15 seconds, The fan runs continuously.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled model, set the humidity extraction level on Maximum.
level
problem.
I hope this helps you to troubleshoot and solve the problem.
Jul 08, 2011 | Maytag M7DH45B2A Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
Ihave the dehumidifier turned on in my basement...fan runs....displays show the humidity, and temperature...but the tray does not fill up with water at all. Is there a specific setting for the humidity..I...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 13, 2010 | Fedders A7DH45B2A Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Just bought this dehumidifier and the fan runs, the compressor kicks in, but after 4 hours, there is not a drop to be found in the bucket. We are in a humid climate and there is definitely moisture in the...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 18, 2010 | Haier DE45EAL Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
547 people viewed this question
Top Whirlpool Dehumidifiers Experts
Marvin
Marvin
Mike
Tim Venetis
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
