Datacard SP35 Printer Logo
Posted on Apr 15, 2011
I have a datacard SP35 printer. I recently changed the ribbon and cleaned the machine. Now the cards are printing however they are only prining all yellow, all pink, all blue, black only, or half pink half yellow. Im not sure whether the ribbon isnt wound to the correct start colour or what is going on. Do you have any suggestions please?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
612
Points
I'm having a similar problem, except some of them randomly print correctly too. Let me know what you find out. Thanks, Glenn [email protected]
My printer DataCard SP 35 started printing only in grayscale suddenly (with a colored ribbon). Before it ware printing colored cards.
I think rain doesn't have anything to do, unless you had your printer outside...
Maybe a light interruption could make your station start over without proper settings. Try checking your printer driver and see if it has the proper settings for ribbon and not printing on black dots.
The SP35 red light is on
please give me the solution as fast as possible.
( out of print ribbon.(pr-01726) replace the K print ribbon, replace the cleaning sleeve, and click ok when ready
2helpful
Want to clean using the cleaning card.how do i do it -data card sp 35plus
You can't - the Cleaning Card supplied with the replacement ribbons is for other models of the Datacard printer, not the SP35 Plus :(
My datacard sp35 will only print in yellow. What
Do you get any errors?
1 st unplug and plug in to reset power
2nd replace print ribbon with new one, could be bad ribbon or bad RFID tag on the ribbon
3rd try printing a different card
if still not working i would recommend sending in for service.
Contact MidWestIdSolutions.com for more info.
Printer printing one color
Go to smart driver printer tool box, then select
brightness 0
contrast 0
sharpness 0
cyan -------centre----------
magenta ------centre----------
yellow -----centre-----------
From toll box select clean printer
Go to advanced setup
select monochrome
Down -3
Left 140
By doing all the above setting hope your problem will get solved , check the ribbon also , move two to three rounds change in the ribbon by manually .
1helpful
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Card jam
You have to change the roller just inside the picker roller.
Sometimes the glue that holds the "cleanig roller" loosen from the pin.
Sorry, bad english... :D
3helpful
Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Card printer is not printing in colour
You have probably bought fake color ribbons , or you have taqken of the blue cup with the rfid inside.. Wich tells the printer what kind of ribbon installed
Printing faintly
It sounds like the printhead temperature needs to be increased in the print driver. This will enhance the color and density of the ribbon transfer to the card.
For techncial assistance for id card printers by blog, visit our blog at www.safecardid.com/blog
Top Datacard Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
Hilary M
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
