Question about Amazon Kindle Wireless Reading Device
I have just received (in Australia) my new Kindle. My previous had 3G and wireless, this one is wireless only. I have been trying to connect to wireless, put in password but it says invalid password. I have done the restart through settings. Doesnt help. Any suggestion? What I want to do is download all the books I have accumulated on my old Kindle. Is there a way of downloading using my computer if i cant connect the Kindle to wireless?
Posted by lorraine972 on
  • lorraine972 Apr 15, 2011
    there was no suggestion about the problem of Kindle not accepting wireless password (it is correct password as iphone and ipad both use it) but the second question asked was answered and gave me a way of downloading without wireless. I am still wondering why wireless wont connect.
SANYADE OMOTOLA
    Genius:
  • 1,622 Answers
How to download books to your Kindle from your computer
We had a reader email us and ask us how he could get a TeleRead-mentioned e-book onto his Kindle. In case anyone else would like a tutorial, here's how to do it.
Download the e-book to your computer. Connect the Kindle to the computer's USB port. The Kindle will show up as a new drive on your computer. If you have an SD card in the Kindle it will show up as a second new drive. Copy, or drag and drop, the e-book to the Documents directory in the Kindle or SD card. That's all there is to it. When you disconnect the Kindle the machine will automatically recognize the new book. Be sure not to disconnect the Kindle until the little silver block at the bottom right stops spinning around.
If you use an SD card, you can dispense with all of the above and just remove the SD card from your Kindle and connect it to a card reader and copy the book directly from your PC to the proper directory on the card. The Kindle will recognize the new book when you plug the card back in. To be safe, shut off the Kindle when removing or inserting the card.
You can also just email it to your kindle's address. Although there is mention of a 10 cent charge per email, no one has ever been charged and Kindle support says there are no plans to do so, at this time.
It's definitely being charged now - I sent a 50 MB PDF to my kindle email address and received a $4 charge.
http://findpdf.net/
and
http://consumerist.com/2009/07/how-to-load-up-your-kindle-with-non-amazon-ebooks.html
Posted on Apr 15, 2011
I can't access the kindle store
Are you out of your usual wi-fi area? You may need to go back and check wi-fi settings and set up again.
From Home or any Settings screen, view the wireless indicators at the upper right corner of your Kindle. While reading, tap the top of the screen to view the wireless indicators.
Wireless Indicator Description Your Kindle is connected to 3G. This may also say EDGE or GPRS.
Note: For 3G enabled devices only Your Kindle is connected to a Wi-Fi network and has a strong signal. The Wi-Fi symbol appears when in range of a trusted Wi-Fi network.
Dec 10, 2016 | Amazon Tablets & eReaders
I am unable to connect my Kindle to my wireless router
to all of the kindle users should check the network settings.
Oct 04, 2014 | Amazon Kindle 3G
What do I do to my lap top or kindle to receive emails
There is no specific email client on the Kindle so you can only receive your emails via the experimental web browser and using a web mail service to access your mail.
Dec 31, 2011 | Amazon Kindle 3G
How do I set up my computer to receive my emails on my kindle?
The only way is to use the experimental browser- at the home screen, press "Menu". Then press "Experimental", followed by "Browser". Then, type your email client. However- email (and the whole browser, really) is sluggish and slow on the Kindle. It is much easier to just check it on a computer, or any other wireless device.
Dec 29, 2011 | Amazon Kindle 3G
My Kindle is not connecting Via 3G. It is 3G enabled.
The information provided below was tested on a Kindle 2, international version with Wi-Fi and 3G.
The Kindle automatically searches for the best connection signal in the area you're in. But for that, you first need to check if the wireless mode is turned on.
If you can see the signal strength bars next to the battery icon at the top, it is on. If close to the battery icon you only see another icon marked OFF, then you need to change that, as follows:
Press MENU,
Move the 5-way controller button up, till the selecting bar is under "Turn Wireless On" and press it once.
The Kindle will start to look for the providers in the area. The kind of connection it is connected to will be shown next to the battery icon and can be 3G, 2G, GPRS, EDGE and 1X. But to see this information, you need to press the MENU button, because it is not shown in the normal view.
That icon at the top indicates the connection that was established by your device.
Another way to check the connection you have is via the settings display, in an undocumented feature. Here, a note of caution: THIS IS A FEATURE NOT DOCUMENTED IN THE KINDLE MANUAL AND YOU WILL BE USING IT AT YOUR SOLELY DISCRETION. IF YOU SELECT A NETWORK THAT DOES NOT PROVIDE THE RIGHT SERVICE, YOU WILL NOT BE ABLE TO CONNECT YOUR DEVICE - YOU SHOULD BETTER LET THE AUTOMATIC SELECTION MODE ON.
If you still want to proceed, you need to press MENU, select Settings and, when the Settings screen is displayed, press type 311.
A warning note indicating that the connection will be lost momentarily and that you may not successfully reconnect to the Amazon Whispernet networks appears. Selecting OK in this panel will take you to the "Available Wireless Providers" screen and the Kindle will take a while to scan all the networks available in your area.
A list of the networks found will be displayed. You can move the cursor and select the one you want, pressing the 5-way controller button. But it is better to select the "Switch automatically" option and let the best option be selected by the Kindle.
I hope these tips can help you solve your problem. Good luck!
Mar 09, 2011 | Amazon Kindle Wireless Reading Device
Hello, I just recieved a email from Amazon about a new update, I switched my Kindle from 3G to wi fi and recieved the update. How do i switch back to 3G? Thank you
It will automatically use whatever connection is best, so if you have a wireless connection configured, it will use that, but once you are out of range of any configured wireless network, it will use 3G connection.
Feb 28, 2011 | Amazon Kindle 3G
I have the kindle 3.0.2, I have wifi but i dont have 3g i will like to know how i get get 3g on my kindle ?
First of all there are two types of kindle, the kindle 3g + WIFI and the Kindle WIFI. If you bought the kindle WIFI you will be unable to connect to a 3g network. If you bought a 3g model you can access 3g internet by pressing the 'menu' button and then using the 5-way to navigate to 'turn on wireless'. Once wireless is on you can access your browser by clicking menu, scrolling to experimental and then selecting Web Browser
Cheers Sine Wave
Feb 19, 2011 | Amazon Kindle 3G
Wont turn on...before this it would shut off and then power on like it was loading a web page..I have only had this kindle since Christmas.
I received my 3g model for Christmas as well. Last night, it lost wireless connectivity, froze and then would not turn back on, even though it was fully charge. However, I charged overnight again.
This morning, I held the on switch for much longer than normal, until the green light started flickering. I received a simple black screen a few times, but contintinued to hold the switch on. Then it reset itself and all is good.
So I know that sounds like a simple solution, but maybe worth trying. Good luck. It's disgusting, I know. I was so upset.
Jan 24, 2011 | Amazon Kindle 3G
I do not have wireless at home. Received the 3g version of kindle for christmas. It worked all this time. Today, it will not connect. Sees all sorts of wireless connections which are all password...
You are mixing up two things: 3G and Wi-Fi.
3G is a mobile phone data service, supported by selected Kindle devices. Your Kindle 3 3G has a SIM card built inside, just like the fingernail-size chips you put into a mobile phone. Amazon set up contracts with phone service providers in many countries so you can use it to download books to your Kindle at no extra costs for you other than the higher price of Kindle 3 3G compared to the non-3G version. You do not need any extra hardware for this to work, and it will work in most places of the world. This is the guarantee you were promised.
Wi-Fi is a wireless communication standard all Kindle devices support. While most hotels, airports and some restaurants provide free Wi-Fi access for guests, you need your own WLAN router at your home, and pay for your own broadband internet service. The "all sorts of wireless connections which are all password protected" belong to your neighbors and they are password protected so that nobody can take a free ride on the service they pay for.
You can tell the connection status of your Kindle from symbols in in the status bar, at the top right of the screen:
  • If it shows "OFF", wireless connectivity is deactivated and you cannot access the internet from your Kindle, or download books.
  • If it shows "Wi-Fi", the Kindle is connected to a Wi-Fi network. The five bars right of the symbol represent the connection's signal strength, the more bars are black, the better.
  • If it shows "3G", you are connected via 3G mobile data service. The bars right of this symbol refer to mobile phone service signal strength, much like a mobile phone would show you.
If you do not have internet connection with wireless LAN at home, you need to set up your Kindle to use the 3G service. This is the default setting when the device is delivered to you, and I believe it worked until you or somebody else inadvertently changed the configuration.
Follow this step-by-step procedure:
  1. Switch on your Kindle.
  2. Press the "Home" button.
  3. Check the status bar. Does it show the "3G" symbol? If yes, how about signal strength? If you are somehow blocked from mobile phone antennas in your area, signal strength will be low and the Kindle will not have internet access. Move around and see if it becomes better.
  4. Does it show the "OFF" symbol? If yes, press the "Menu" button. A menu of commands should open. Use the four-way button just below "Menu" to underline the top-most option "Turn Wireless On" and press the center of the four-way. The menu list will close, and after a moment Kindle will try to connect to the internet.
  5. Does it show the "Wi-Fi" symbol? If yes, I assume you accidentally connected to a neighbor's Wi-Fi network and its firewall protected, or is too far away to use it. In this case, press the "Menu" button to open the command menu. Use the four-way button just below "Menu" to underline "Settings", second option from the bottom, and press the center of of the four-way. The settings menu will open. Use the four-way button to navigate down to "Wi-Fi Settings" (the text "view" must be underlined) and press the center of the four-way. The list of Wi-Fi networks open. Navigate down using the four-way to any network with the text "forget" on it and press the center of the four-way.
Please let me know if you encounter problems in following these instructions, and I'll try to assist you further.
Jan 08, 2011 | Amazon Kindle 3G
My kindle will not connect tot he wireless in a 3g area
Hi! I'm not sure if you're still in need of a solution but I'm currently going through the same issue. My Kindle 2 has not connected to Whispernet for over a week. I've been back and forth with Customer Service (1-866-321-8851 or 1-206-266-0927 if you're calling from outside the U.S) and after an exhaustive search for any possible answer, they told me it was a network connectivity issue and forwarded a service note to AT&T/Sprint, and promised to notify me as soon as possible. I'm still waiting to hear from them. Yesterday my Kindle connected to Whispernet for all of three minutes (just long enough to download a book I bought over a week ago) and now nothing. I've even tried switching wireless networks in range (go to settings, hit menu, type 311 - select different wireless networks) but to no avail. So basically, the best thing you can do after you have tried a soft/hard reset, a fully charged battery and toggling wireless off and on is to call tech support. Do you happen to be in Orange County, New York? If you are, maybe it's a malfunctioning cell tower. Hope this helps!
Apr 13, 2010 | Amazon Kindle Wireless Reading Device
Amazon Kindle Wireless Reading Device Logo
433 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
