Zenith XBV713 Logo
Posted on Apr 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just ordered a replacement remote control for my XBV713 DVD/VCR combo from Electronic Repair Service in Thomasville, Georgia. Will it work when I receive it, or will I need a code to match it with my machine? Thanks!
Anonymous
Level 2:
Sergeant:
  • Expert 378 Answers
  • Posted on Apr 15, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
378
Questions
0
Helped
186503
Points
794
If it's an exact replacement for the remote for your equipment, then it will work out of the box.
Testimonial: "Thanks for your help, and for the fast response!"
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
It's not working what can I do to program one for all controller to rca tv
HI,
The One For All 3 Device Universal Remote Control is preprogrammed at the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola cable box. To control devices other than the default brands, perform the following steps; otherwise skip this section:
HOW TO PROGRAM
1.Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc)
NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step.
( CHECK THE BELLOW ADDED LINK TO FIND THE CODE )
2.On the remote control, press a device key once (i.e., DVD/VCR, CBL/SAT, or TV).
NOTE: To program control of a VCR, PVR (or DVR), TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCRonce. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
NOTE: To program control of a DVD Player, DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCRonce. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SATonce.
3. Press and hold SET until the LED (red light) blinks twice, then release SET
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice.
NOTE: If the LEDdid not blink twice, repeat steps 2 through 4 and enter the same code again.
5.Aim the remote control at the device and press POWER once. The device should turn off.
If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For next code.
NOTE: If the device does not have a POWER key, press PLAY
6. Repeat steps 1 through 5 for each device you want to control. For future reference, write down each working device code following.
Electronics Equipment Repair Center ONE FOR ALL URC3021 UNIVERSAL REMOTE...
Who can tell me the code for THOMSON CB1000 DVD Recorder/VCR Combo remote control?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
1helpful
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
applicable, insert media (e.g., cassette or disc).
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
Combo, press CBL/SAT once.
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
6.You are set
thanx
Need a region code hack for Zenith DVD/VCR combo XBV713
you might want to region hack it.
the procedure can be found here
2answers
I need a region code hack for Zenith DVD/VCR combo XBV713
OK... now some DVDs cannot be hacked / or unlocked for regions BUT
go to e-Bay and search for dvd region unlock code... there are some there BUT go into a couple to see if they will let you contact them FIRST to see if yours can be unlocked BEFORE YOU BUY.
Good luck...
1helpful
Sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
2answers
DVD drawer in TV/VCR/DVD combo won't open
Hi, The problem may be mechanical or electronic. If the drawer is stuck from being bent or jammed it is mechanical. If the system controlling IC circuit is defective, then it is electronic. If it is still under warranty the factory should be responsible for it. If it is not under warranty, the cost of repair is likely to be more than the price of a new dvd player! Sorry, Daniel
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
