Question about Texas Instruments TI-30XA Calculator
I need the EXACT solution for -7 + square root of 61 divided by 2. I have a Ti-30XA calculator and I don't know how to do this.
Joe2
    President:
  • 2,080 Answers
It is unclear whether your equation is:
a: ((SQRT61) - 7) / 2
or
b: ((SQRT61) / 2) - 7
For a:
Type 61 SQRT.
Subtract 7.
Equals.
Divide by 2.
Equals. (Should be 0.4051248...)
For b:
Type 61 then SQRT.
Then divide by 2.
Equals.
Then subtract 7.
Equals. (Should be -3.094875...)
Good luck.
Posted on Apr 15, 2011
  • Joe2
    Joe2 Apr 15, 2011
    It could even be c: (SQRT(61 / 2)) - 7 which is -1.47731949...
I do not know how to use the tan-1 when square roots are involved.
Use parentheses. If you do not have parentheses (doubtful), calculate first SQRT(2)/2 =
Result is displayed and saved in ANS memory. Now calculate the arc tan of ANS.
How to do square root on calculator ti 30xa
Use the square-root key, two keys above the 9 key. For example, to calculate the square root of 2, press 2 square-root =
3helpful
How can I find the square root of 39 on my ti-30xa? Also I would like to know how to find the cube of 9482... Help
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] =
[cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
Now that I know where the square root button is on my TI-30Xa, how do I calculate a "geometric mean" when the equation inclues a time period? For example the problem is setup like this: 6...
You don't want the square root. In this example, you want the sixth root.
Press 4 5 2nd [xth-root] 6 =
The xth-root is the shifted function of the y^x key, located just above the divide key.
2helpful
Which button do I use for the square root button? I have to perform math problems on... geometric mean population standard deviation sample standard deviation
The square root button is two up from the 9 key, just to the left of the divide key. To calculate the square root of 2, for example, press 2 square-root =
1helpful
How do i calculate square roots with this?
Use the square-root key to the left of the divide key. To calculate the square root of 4, press 4 square-root =
1helpful
How to get the square root of a number
Use the square-root key to the left of the divide key. To compute the square root of 4, press 4 square-root = and see 2.
How do I find the square root of a number? and how do I enter scientific equations?
For square roots, use the square root key just to the left of the divide key. For example, 4 square-root = will give you 2.
The calculator doesn't have any way to store equations, scientific or otherwise. If you mean scientific notation, use the EE key just above the 7 key to enter exponents. For example, to enter 1.23x10^6, press 1 . 2 3 EE 6. For negative exponents, make sure to use the +- key to the right of the decimal point instead of the - key.
3helpful
Ok im using the Ti 30xa how do i find the square root
1. Type in the number you wish to find the square root of.
2. Press the square root button. It is located to the immediate left of the divide button.
17helpful
3answers
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
