Download with Google Chrome
Step 1: Visit the web page that contains the SWF video to download and wait for it to load completely. Right-click on any area on the page without content and choose "Inspect Element".
Step 2: You can see the Developer Tools appear at the bottom separately. Click on the "Search" tool with a magnifying glass icon at very bottom of the browser. It allows you to select an element t in the page.
Step 3: Go to the web page area and click on the SWF to download, then the object will be highlighted in the code area too.
Step 4: Next, select the URL of the SWF file, create a new tab in Chrome and paste the URL into the address bar to open it. Click on the menu button at upper right corner to expand it and choose "Save page as" to download SWF to your hard drive.
Download with Leawo Video Downloader
Step 1. Download and open Leawo Video Downloader.
Step 2. paste video URL in the address box. Or you can watch the videos with the built-in browser online and the videos will be downloaded at the same time.
Step 3. There is a little green arrow on the right bar. Click it to open the wait-to-select panel. You can choose the video with the appropriate resolution. Then click the download icon.
Step 4. You can check the downloading videos under the "Downloading" panel.
Or you can get the url file and insert
on other online webpage to download
the other page download the file for you
just insert the url
If you want to save an .flv from a web page, you can use IDM, and if you want to save a .swf file you can save the page as complete .htm file and then open the web_page_name_files folder in Microsoft Windows.
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
First you need to create a desktop.ini file in your flash
drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to
All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a
".jpg" file
Open desktop.ini file from your flash drive. Copy and paste
below code to it.
Last line of the code, you can see
"IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper
name.
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
Save your file. Unplugged the flash drive from PC and plug
it again. That's it.
If you need more information
Visit SmartUSB.net
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change your flash
drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
