Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
how do you get the internet on this my says no - mr_fix3er_0.pngoads/images/mr_fix3er_0.png" alt="mr_fix3er_0.png" class="h_mi" />
2- Scroll over to the how do you get the internet on this my says no - mr_fix3er_1.png select "Internet."
3-Now choose "Connection Settihow do you get the internet on this my says no - mr_fix3er_3.pngr />
5-Click on "Search for an Access Point."
6-The Nintendo DSi will search for any wireless networks within range. Once it is finished how do you get the internet on this my says no - mr_fix3er_5.pngill display the names of all the wireless networks it finds. Look for your wireless network.
7-What to do next will depend on the "lock" icohow do you get the internet on this my says no - mr_fix3er_6.pngto your network on the Nintendo DSi.
WEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
WPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
Hi there. The error indicates that there is no available WiFi in your area. If ever there is WiFi and you still cannot connect then that means that the protection on the wireless connection is WPA2-PSK enabled. To be able to use your DSi to connect to a WPA protected wireless connection, do the following:
1.Go to "Settings" (wrench icon)
2.Go to third page, and select "Internet"
3.Go to "Connection Settings"
4.Then go to "Advanced Settings"
Change WEP to WPA and then it should work.
Hi
Please check
whether the below point will be helpful.
