Question about Hitachi 43F300 43" Rear Projection Television
When I plug on the tv after about 2 seconds I hear clix and it cuts off like if something trips off and the tv does not turn on its a hitachi 43f300
Posted by rishtag on
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Hitachi 43F300 43 in. Rear
is the light blinking?
Posted on Jan 10, 2008
Anonymous
  • 1847 Answers
reset the projectorsettings
Posted on Jun 23, 2008
ladywinn
ladywinn
  • 5138 Answers
BAD STKs YOU have 2 of them replace them both 392-110s up grade 180s.
Posted on Sep 11, 2008
ladywinn
ladywinn
  • 5138 Answers
SOURCE: x480306 for Hitachi 43F300
Replace both STKs 392-110s
Anonymous
  • 61 Answers
SOURCE: Hitachi 43F300 convergence
Do not replace whole convergence board.Because convergence data stored in old board cannot transfered to your new board.Means in your new board there is no convergence data.Unless you have the service manual and know how to get service menu.
I believe if you have convergence problem one of your IC (STK) is bad along with couple of small
Value resistance.
Dont forgat to Rate!
Good Luck
Dals123
Posted on Oct 22, 2008
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
Convergence problem
it sounds as though you need to have the tv converged
Oct 30, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300
Sep 10, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43f300
the set has gone into a shut down to protect itself,poss. convergence or deflection fault.
Jul 31, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43 in. Rear hrojection TV
you possibly have a deflection or convergence fault.
Jul 27, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43 in. Rear... Problem:
units in shut down to protect further damage,poss. power supply or deflection fault
Jul 21, 2008 | Hitachi 43F300 43" Rear Projection...
1997 hitachi tv
Listen carefully to the sound of the exhaust fan. If you don't hear it it could be that the tv's fail safe shutdown is being tripped. Your tv is overheating.
Dec 19, 2007 | Hitachi 53FDX20B 53" Rear Projection...
(Hitachi 43F300) Turning its self off
Sounds like it is going into shutdown mode. When the TV power supply and system control sense an overload the system control turns the TV off to prevent further damage from happening. I suspect it is a shorted convergence IC. It would be best to call a service center to repair the TV.
May 18, 2007 | Hitachi 43F300 43" Rear Projection...
Open Questions:
Hitachi 43F300 43" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
