Question about Shurflo OnDemand Diaphragm Pump 28 GPM 12 Volt 12in
I have a Snyder Industries sprayer for and ATV with a Shurflo Diaphram Pump 1.4gpm, 12V 7A 60 PSI. Seems to run ok, when first spraying it flows well then turns to a trickle or drip....I have disconnedted all connections and can't find the problem. Any suggestions?
Posted by rkpook on
Paul Beyer
  • 528 Answers
There is a filter screen on the pickup tube in the tank (or there should be) if there is a lot of debris in the tank it will slowly start to plug up the screen and reduce the liquid intake for the pump. If that is not the case then take the spray nasals off and clear the debris from them. Hope this helps you.
Posted on Apr 14, 2011
I have a Husky power washer 2600 psi starts & runs until it seems to build Pressure and will not spray then motor boggs to a stall
Some models have a tiny orifice in the adjustable spray head.(if equipped) Which can become clogged by debris or calcium buildup. Water should flow through even when unit is off and sprayer handle(on/off) is operated if there is no water then you definitely have a clog.
Oct 31, 2013 | Garden
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Extreme pro blaster 5901-2112 pump.will not pull water 6ft. Drained and ran rv anti freeze thru the past 2 winters and pump performed well last three seasons. Placing finger over intake side with pump...
I can't find your particular model pump but, in the picture shown, if thats yours, it looks like two pumps in one. Anyway, I'm pretty familiar with Shurflo pumps and they are diaphram pumps and, the antifreeze may have taken out the diaphams. I'd like to see a bigger picture of it.
http://www.shurflo.com/files/Education-Center/Product%20Data%20Sheets/Fresh%20Water%20Pumps/pds-Extreme%20SS%205.7%2012v%205901-0201%2011.pdf
The pump head should look something like this. I'd replace the diaphram assy.
Jun 15, 2011 | Shurflo Extreme Series High Flow Strainer...
The spray stream is not consistent. After 2 - 3
The pump cycles to keep the pressure constant. It could be the impeller---they sell special ones to use with nonaqueous sprays--ie petroleum based. If petro was used at some time, the impeller might be bad.
Mar 01, 2010 | Northstar ATV Broadcast Spot Sprayer 16...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a Fimco 2.1 gpm pump that worked fine last week. I ran it until it didn't spray anymore. This week the motor runs but it seems to have lost its prime,it won't pump.Any ideas? The filter is clean. No...
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
Jun 25, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Shurflo OnDemand Diaphragm Pump  28 GPM 12 Volt 12in Logo
259 people viewed this question
Top Shurflo Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Shurflo Plumbing Expert? Answer questions, earn points and help others
