Question about Denpa MP38 Voice Recorder
I lost the external cord that connects the recorder to the phone adapter. How can I get that cord replaced?
Posted by griffic1 on
Javier Gonzalez
  • 207 Answers
Hello I'm not sure exactly what is the size jack on your unit but if you know, you can chose any of the following on at http://www.tvps.com/Departments/Telephone-Recording/Telephone-Recording-Adapters.aspx
Posted on Apr 15, 2011
I want to hook up my CD-BA2100 to my Inspiron 6000 laptop but i don't know how to hook it up or what to use.
The SHARP CD-BA2100 is a "stand-alone" cassette/CD/AM/FM player.
Its manual states that it can accept left/right stereo audio output, such as from your laptop, if you purchase the correct adapter cable (from "line-out" or "head-phones-out" on your laptop):
Video/Auxiliary (Audio signal) input
To listen to or record signals from external sources through this unit:
1 Use a separately available RCA cord to connect the desired external unit to the VIDEO/AUX jacks. (red ® right channel, white ® left channel) * When using video equipment (Laser Disc player or VCR), be sure to connect the audio output to this unit, and the video output to a television.
2 Press the ON/STAND-BY button to turn the power on.
3 Press the VIDEO/AUX button.
4 Operate the external unit.
5 To record the sound from the external unit ...
i.e., you can use it as the speakers for your laptop, instead of the laptop's tiny, built-in, speakers.
Mar 31, 2011 | Computers & Internet
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
HOW DO I INSTAL A TOSHIBA EXTERNAL DVD RECORDER TO SAMSUNG SMT-190DN..
If your are going to install the dvd recorder into your other device, follow this few steps.
  1. Place your external DVD Multi-Recorder drive in the stand. Otherwise, lay it down horizontally if you're not going to be using the stand.
  2. Turn on device.
  3. Plug one end of the USB cable into one of the dvr USB ports. Then connect the other end into the external DVD Multi-Recorder drive.
  4. Plug the power cord into the AC adapter. Then connect the cord into the drive's jack. Connect the other end into the power outlet.
Hope this helps
Nov 23, 2009 | Samsung 4 Channel Dvr
I have a western digital dual option external hard drive that is a couple of years old and I lost the power supply while moving. Can you help me? The model number is wd1600B015
Overview for the WD1600B015 dual option USB:
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1274
Power supply not available in WD shop, but there's worldwide email and telephone support: select your country from the next page:
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1048
Send your request to the WD support desk in your country.
When using the telephone line: in Europe, phone numbers starting with 00800 are international free call numbers. Using any other phone number, check your local provider.
Notice: when the power adapter has a seperate cord connected from the wall outlet to the adapter, mostly this will not be provided and has to be bought elsewhere ( Ask when ordering the adapter ).
Oct 18, 2009 | Computers & Internet
I lost the power cord to my external hard drive.
Hi annabel_nyc,
You need to make sure that you get a compatible power adapter for that model. Most of Acomdata external drives use a 12v adapter, but not all. If you plug the wrong voltage into the drive, you do have the possiblity of frying your external. I'd check with your manual or post back your model number so I can look that adapter up.
Good Luck
Mark
Aug 30, 2009 | Acomdata Computers & Internet
Will not work connected to telephone using adaptor
This recorder is designed to be used on analog phone lines with the included adapter. If you have a digital type phone system it will not work by plugging it into the wall jack. It may even damage the recorder.
To record YOUR calls you need the handset adapter which hooks in between the handset and your phone then patches into the recorder.
You can get one at SpyGadgets.com
Mar 24, 2009 | Diasonic DDR-4100 MP3 Player
Lost ac/dc adapter for a 320 GB Simpletech External Hard Drive
I have the 320GB Simpletech External Hard Drive.
The AC adapter Model number is SAWA-05-153
The output is +12V --- 1.5A
Nov 16, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Inspiron 5160 screen is blank
It seems to me the LCD cable is either not properly unplugged or LCD ha gone bad.
Connect external monitor to the laptop and check if you have the Video on the external monior. If everything looks fine on external monitor then you can get the LCD replaced.
In case system does not power up and there are no indications of power.
Here are the steps:
Connect only the AC Adapter and take the battery out.
Check if you have a green led lit on the AC Adapter.
If AC Adapter does not has a green led please replace it with a known good AC Adapter.
If the AC Adapter has a green led but still no power it can be the system board which has gone bad.
Sep 25, 2008 | Dell Inspiron 5160 Notebook
Telephone recording
Yeah, um connect it to a phone in a room that is normally isolated from traffic. Not an ideal solution but as it is a machine and has only an external mic (it doesn't have an internal mic does it?) this is the only solution really, remove all noise except phone conversations.
Sep 25, 2007 | Denpa USB-24 Digital Voice Recorder
Change Answering Machine message in Lucent 1872 corded phone
I have this phone and manual. In order to record a new message follow this, 1. To record a new message 2. Pres [ANNC] 3. Choose the message location by pressing [Select] untill the appropiate mailbox is located. 4. Press [Record]. Begin speeking after the beep. 5. When finished press [Stop] 6. Repeat above to record another announcemnt GarryM
Jan 09, 2007 | Lucent 1872 Corded Phone
Open Questions:
Denpa MP38 Voice Recorder Logo
87 people viewed this question
Top Denpa Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
