Cycling Logo
Posted on Apr 14, 2011
Just bought magnum 3016 coil cable lock. How do I open it and set own combination?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
951
Points
Thanks that worked for me to. To change the code open.....enter current code.......turn the metal wheel (saying set ->) clockwise until it stops.........set the new code........... turn the metal wheel anti clockwise until it stops.......the new code is set.
2001 Isuzu rodeo trying to take out the ignition switch, but have no key, and it is set in the lock position
usa CAR? ,NO VIN,
NOR IF IMMO FITTED
i WILL rtm to you, service manual on said LOCK
16 STEPS THERE ARE.:
Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
Turn the ignition switch to LOCK.
Disconnect the negative battery cable, and wait at least 5 minutes.
Disconnect the yellow 2-way SRS connector located under the steering column.
WARNING
The wheels of the vehicle must be straight ahead and the steering column in the "LOCK" position before disconnecting the steering wheel. Failure to do so will cause the coil assembly to become uncentered which will cause damage to the coil assembly.
Remove the engine hood opening lever and steering lower cover.
Remove driver knee bolster (reinforcement).
Loosen the inflator module fixing bolt from behind the steering wheel assembly using a Torx® driver or equivalent until the inflator module can be released from steering assembly.
1. Inflator module 2. Steering wheel 3. Steering column cover 4. Combination switch and SRS coil assembly 5. Snap ring 6. Cushion rubber 7. Lock cylinder assembly 8. Instrument panel lower cover 9. Driver knee bolster (reinforcement) 10. Shift lock cable (for A/T)
42050 images-42050_rode_g0027
Disconnect the yellow 2-way SRS connector and horn lead located behind the inflator module
Apply a setting mark (1) across the steering wheel and shaft so parts can be reassembled in their original position, then remove steering wheel
Move the front wheels to the straight ahead position, then use steering wheel remover J-29752 to remove the steering wheel
WARNING
Never apply force to the steering wheel in direction of the shaft by using a hammer or other impact tools in an attempt to remove the steering wheel. The steering shaft is designed as an energy absorbing unit. Remove steering column cover.
12. Disconnect the wiring harness connectors located under the steering column.
Remove the combination switch assembly with SRS coil.
NOTE
The SRS coil is a part of the combination switch assembly, which can not be replaced separately. Therefore, be sure not to remove the SRS coil from the combination switch assembly.
Remove snap ring. <<<<<<I GUESS YOU ARE HERE?
Remove the rubber cushion.
Remove shift lock cable (for A/T).
Disconnect the starter switch harness connector located under the 16:steering column then remove lock cylinder a
ssembly.
Model 3016. Can't find the learn button to reprogram the remote
How do I change combination?
Google
make model manual
or
make model change combination
It is impossible for us to guess what you have. Here are a few just for fun!
"Set-Your-Own" Combination Locks Instructions ' FAQs
https://www.masterlock.eu > ... > FAQs > Padlocks
Q: How do I set or reset the combination on my bike cable lock model 8221, 8231, 8120, 8190, 8226?
Change my combination? - S&G - Sargent & Greenleaf
https://sargentandgreenleaf.com > knowledgebase > kno...
Do not remove lock cover. If an error is made, re-dial the entire combination. A U8 change key is required to change the combination. If you ...
Support FAQs ' Master Lock
https://www.masterlock.com > Support
Q: How do I set or reset a Master Lock combination padlock that has a ... Q: How do I change the combination on a Set-Your-Own combination lock model #643D?
How do I set or reset the combination on my Lock Box?
https://www.snapsafe.com > support > faqs > how-do-i-...
Begin by opening your Combination Lock Box. To open a new lock box for the first time: Move all 3 digits to 0-0-0. Make sure all digits are centered on the ...
2helpful
2answers
How to set the combination on a Blackburn ANGOLA COMBO CABLE LOCK
Open the lock using the original combination, which was 0000 for mine. Once open, you will find two tabs on the lock side--on top and bottom of the lock portal. Push in both tabs, and hold them down while you set the new combination. Once it is set, put the post back in to make sure it is still open. Twist the dials to lock it, and then you should be able to unlock using your new combination.
8helpful
I bought a roadster combination spiral lock. there are no instructions, so I can't change the setting from the default setting
I bought one today and the shop told me what to do: assuming you have the lock open...
Look down the end with the hole where there is a knurled knob inscribed "reset" on the end with an arrow . Turn to the right - clockwise - following the arrow. Now set the new number you want. Then twist the knurled knob back to the left... and you've done it!
Robert Clark
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
1helpful
Just purchased my sunlite lock but the directions where thrown out by the retailer.....how do i set my lock combonation? I have it on all zero's now and it is unlocked...thanks
We just got a sunlite lock and figured it out. After it is unlocked with 0000 and the lock opened, the end spins to a "set" position. Set the numbers you want, spin the end back, and lock will be set to those numbers.
Hi, I bought a Krypto bicycle lock over 5 years ago. I don't see it displayed on your website. It has yellow ends with 4 digit combination numbers red on black.The rope cable is grey and has a clear...
Krypto has the resetting of the combination lock on their website (under Maintenance) but if you cannot unlock it in the first place you can not reset the combination. You have to know the old combination to get it open.
17helpful
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Top Magnum Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Magnum Cycling Expert? Answer questions, earn points and help others
